L.E.D. Hood Lights
Old Jan 31, 2004 | 10:20 PM
SFLG35's Avatar
FGC President
L.E.D. Hood Lights
Well here they are. Finally got around to making up the other side and installing them.
Parts: all came from radio shack
4 – 5mm Blue LED part #: 276-316 - 3.7volt – 20mA – 2600mcd
4 – Panel mount LED Holders part #: 276-080
2 – 470-ohm Resistors part #: 271-1317 – ¼ watt – 5% tolerance
2 – Mini project enclosure part #: 270-288
1 – Tamper switch part #:49-528
1 – Automotive inline fuse holder part #: 270-1238
1 - .315-Amp Fast-Acting Fuse part #: 270-1046
Some butt connectors
18 gauge wire
1st I soldiered the two negative wires coming off the leds to a negative wire that goes out of the project box. Then I soldiered the two positive wires coming off the leds to a 470ohm resistor. Next I soldier the other end of the resistor to another wire that runs out of the box.
Finished product.
Daniel
5AT Coupe / DP / Willow / Aero / Premium / 3M Clear Bra / 5% Tint All Round / Ground Kit / Clear Corners / Piaas Everywhere / Shock Sensor / L.E.D. Hood Lights
Old Jan 31, 2004 | 10:22 PM
Meatshackle's Avatar
Deep Sea Moderator
Re: L.E.D. Hood Lights
Where are the pics??????
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest thread
SFLG35's Avatar
FGC President
finished product
Daniel
Old Jan 31, 2004 | 10:24 PM
SFLG35's Avatar
FGC President
After that I drilled 2 holes in the hood liner and pushed the led holders through. Then I drilled 2 holes on one side of the box and pushed the holder through that as well. Then I screwed on the nut that came with the holders to hold the box to the hood liner.
Back of PCB
Daniel
Forte's Avatar
Where is the light coming from?
Old Jan 31, 2004 | 10:26 PM
SFLG35's Avatar
FGC President
Then I drilled two small holes for the wires to come out on the other side of the box. Then I pushed the leds in to the holders and put the other side of the box on and screwed it together.
Daniel
Old Jan 31, 2004 | 10:27 PM
Deep Sea Moderator
That looks pretty nice.
Now you need a "Powered by Radio Shack" sticker.
Russ
Black 6MT Coupe
Jax, FL
Old Jan 31, 2004 | 10:28 PM
SFLG35's Avatar
FGC President
Finished back
Daniel
Old Jan 31, 2004 | 10:31 PM
SFLG35's Avatar
FGC President
finished front
Daniel
Old Jan 31, 2004 | 10:34 PM
SFLG35's Avatar
FGC President
Both sides in place and connected together
Daniel
Old Jan 31, 2004 | 10:37 PM
SFLG35's Avatar
FGC President
Finished front2
Daniel
Old Jan 31, 2004 | 10:38 PM
SFLG35's Avatar
FGC President
Tamper switch
Daniel
Old Jan 31, 2004 | 10:40 PM
SFLG35's Avatar
FGC President
Next I connected the wires and reinstalled the hood liner. I ran the wires down the side and into the battery compartment. The negative one I attached to the negative battery terminal and ran the other one out to the tamper switch. Then I ran another wire out of the battery compartment and down to the hood switch where the tamper switch is mounted and connected them to the tamper switch. I put an inline fuse on the wire that comes off the battery and runs down to the tamper switch. I mounted the tamper switch using zip ties. I tried several locations around the hood switch but none of which would work, so I had to mount it as shown.
Daniel
Old Jan 31, 2004 | 10:42 PM
SFLG35's Avatar
FGC President
Battery connections and fuse
Daniel
Old Jan 31, 2004 | 10:44 PM
SFLG35's Avatar
FGC President
hood shot
Daniel
