sidemarker/blinker in headlight HELP!
Old Sep 6, 2007 | 12:45 AM
myv6isfaster's Avatar
so tonight the led bulb blinker in my driver side headlight turned loose and it flickered on and off...i tried to pull it out but the led bulb got stuck inside my headlight and i dunno how to pull it out....i just put my hand in from the hood and now i cant do anything! the bulb is stuck inside my headlight and i dont know how to put back the thing that holds the led headlight blinker...i'll try to post pics tomorrow
need help guys!! should i take it to the dealer? or just try to fix it on my own? i have crappy DIY skill
Old Sep 6, 2007 | 01:01 AM
travie46's Avatar
you need remove the headlight
or check this DIY maybe this can help you
Old Sep 6, 2007 | 01:20 AM
thanks but i'm even more worried that i wont be able to get the led blinker out of the headlight, i expected it to slide down but instead it just sat there
edit: this bulb is the one that lights up the vertical strip on the outer edge of the headlight...its not the blinker, it usually just lights up when you turn the headlights on
i'm gonna try taking the wheel well off tomorrow i guess...hopefully the bulb will slide down..if its totally stuck, then i'm taking it to the dealer
Old Sep 6, 2007 | 09:00 AM
digital_nrg's Avatar
why take to the dealer? You can take off the front bumper and then the headlight will be easily loosen up. I wouldn't pay for dealer if I was you.
Old Sep 6, 2007 | 08:36 PM
fixed it this evening yeay, i end up changing out the bulbs
Old Sep 7, 2007 | 06:49 AM
TurboDreamzG's Avatar
Glad to hear you got it fixed, I was gonna say it's gonna suck if you have to bake those things and take off the lens just to retrieve the led....lol.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
