Question on non HID light and high beam...
Old Sep 25, 2007 | 05:36 PM
virtualbong's Avatar
So when I put my lights on, the HIDs come on and the right daytime (high beam) light comes on but the left one doesn't. Its that low beam light where the high beam shines. Well, it only shines when I turn the high beam on. What do I have to do to fix this?
Old Sep 25, 2007 | 05:41 PM
patman530's Avatar
I think you are referring to the Fog/High beam. These bulbs are dual filament, and it sounds like the left bulb may be bad. Try replacing the bulb.
Old Sep 25, 2007 | 06:22 PM
Beebo's Avatar
take it to the dealer i had linda the same problem but they said nothing was wrong
Old Sep 25, 2007 | 11:08 PM
ravi4221988's Avatar
yeah i still have this problem i called up the dealer they said they will call me back but now im just gonna go down there...thanks for the help i couldn't figure it out either
Old Oct 3, 2007 | 11:36 AM
So this is covered under warranty?
Old Oct 3, 2007 | 08:44 PM
Beebo's Avatar
they said not for me
Old Oct 5, 2007 | 10:46 AM
F that! Is there a way for us to fix it instead of having them do it?
Old Oct 6, 2007 | 11:23 AM
all right im the other kid who has this problem...well i got it fixed and holy s**t am i pissed off b/c it still looks the same...is it alright if you can show me whats wrong i mean like you can see one light on the ground but the other is somewhere else right?
Old Oct 6, 2007 | 03:41 PM
Beebo's Avatar
idk i searched but didnt find anything
Old Oct 7, 2007 | 12:27 AM
well on mine they said it was your lights are on warranty...but they first said nothing was wrong... then they said that one of the mirrors were moved a lil' if i were you i'd call and ask if your lights are still under warranty
Old Oct 9, 2007 | 06:27 PM
No, the left one isn't on and only turns on when the high beam comes on.
Old Oct 10, 2007 | 06:00 PM
hmm i see well the ting im looking at right now were the conversion kits on the lights here http://clearcorners.com/ but its really expensive thats the problem im having right now since it didnt work out at the dealership
Old Nov 9, 2007 | 01:00 PM
Why did I not see this post before...so if the bulb is dual filament and one is for the fog and one is for the high beam, then that's gotta be the problem. How tough is it to exchange the bulb? And I have to go back to the warranty thing...would a bulb be covered under warranty?
Old Nov 9, 2007 | 01:17 PM
patman530's Avatar
the bulb (H4 9003 HB2) may or may not be covered under warranty, i'm not sure, but it is relatively inexpensive. changing of the bulb is easy, once you have the housing in front of you, it is pretty much self explanatory, un-do the clip that holds the bulb in place, as well as the wire connector. I have been able to change my city lights on my 06 headlights without actually removing the bumper/headlight housing, but it was difficult since there was not much space, and you have to feel for where the bulb goes. your best bet may be to just remove the bumper, the headlights, and change them out. here is the diy: https://g35driver.com/forums/lighting/81002-g35-coupe-headlight-removal-guide-3-simple-steps.html
Muski_G
Dec 1, 2023 11:11 AM
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
