How closely do the Sylvania Silverstar Ultra (9003SU) match the '04 coupe headlights?
Nov 15, 2007 | 12:05 AM
I'm trying to decide which fog light bulbs to get and I'm pretty sure I'm going to get the Sylvania Silverstar Ultra's, 9003SU. Does anyone with these bulbs know how closely they match the stock headlight bulbs on an '04 coupe? Also, I have V-LEDs High Power White bulbs in my clearance strip and clear corners. Will it match these well?
Reply 0
Nov 15, 2007 | 12:10 AM
DOHH!!!
try again sir... if you are speaking of the upper portion of your headlights, then you will need D2R bulbs, which are HID
if you are speaking of the lower portion, those use H4's if i'm not mistaken
have a nice day!!
EDIT: 9003 is in fact H4... forgot
and didn't see that you put fog lights... i stand corrected
Reply 0
Jul 11, 2010 | 11:37 PM
Looks like it has only been 4 years since your post - did you sort out what lights to use? I'm looking to do the same thing: I want to upgrade the fog/highbeam lights to better match the main headlight HIDs. did you find a solution you were happy with?
Reply 0
