Fog lights no worky!
Old Jan 16, 2008 | 09:07 PM
spin117's Avatar
Hey All,
Are the 06 Coupe's Fog lights on their own fused circuit? I opened both the engine fusebox (by the battery) and the lower kick panel fusebox and see no mention of any headlight fuses at all!
I had replaced them with Silverstars about 9 months ago, but I would be surprised to notice that they both blew at the same time. Are the Fog lights on the same circuit as any other electrical device? As far as I can tell all other electronics are working A-OK.
I appreciate the help guys!!!!
Old Jan 16, 2008 | 09:12 PM
redlude97's Avatar
As far as I know , they are on the same circuit, why don't you just pull the bulbs and see if they are blown?
Old Jan 16, 2008 | 09:23 PM
spin117's Avatar
Well mostly bc its a pain in the ballz to take off the splash guards from each wheel well. Just wanted to check the obvious before doing alot of possibly unnecessary unscrewing
Old Jan 16, 2008 | 10:22 PM
avs007's Avatar
Originally Posted by spin117
Hey All,
You are looking in the wrong spot. The fuse for the fog lights are in the IPDM E/R. According to the service manual, this thing is located behind the battery. (It's not in the fuse block). The fuse for the fog, is the one labeled #88. The relay for the fog is in the IPDM E/R as well.
Here is a picture from the service manual that describes where this is:
Old Jan 16, 2008 | 10:25 PM
spin117's Avatar
Many Thanks!!!!!!
Old Jan 17, 2008 | 09:24 PM
avs007's Avatar
Many Thanks!!!!!!
I'm curious to know what was causing your fogs to not work... I'm guessing the relay is shot, since I don't think I've ever blown a headlight/foglight fuse in my entire life
Old Feb 18, 2008 | 10:38 PM
spin117's Avatar
Well pretty much, my gay *** silverstars burned out. Dealership charged me 55 to fix it damn.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Jnm07
Sep 5, 2015 01:16 AM
attarday
Jul 15, 2015 04:03 PM
