Headlight replacement after accident
Old Feb 25, 2008 | 10:37 AM
Nappy's Avatar
I have an '03 coupe and both my headlights were cracked in an accident. I'm having problems with the insurance company since I was struck primarily on one side and they don't think both headlights could have been damaged.
Anyway, instead of fighting with them I may just say forget it...since I can get a set of '06 projectors online for ~$500 and they are paying $600 for one stock headlight through the dealership.
I read through the forum and had just a couple questions left:
1. Are there pictures anywhere of unmodded '03-05 lights compared to unmodded '06...off and on?
2. I saw the thread for removing my headlights...what is involved with putting in the '06 projectors? Is it a simple swap or is more involved?
Thanks in advance for the help...hoping I can get this figured out today so I can let the body shop know what I'm going to do.
Old Feb 25, 2008 | 01:12 PM
eminem's Avatar
sell me your old 03 headlights if you decide to get the 06 headlights
Old Feb 25, 2008 | 01:20 PM
Boston's Avatar
06 projectors are a direct swap; plug and play. You will use your current ballast off the 03 lights.
Old Feb 25, 2008 | 02:31 PM
Nappy's Avatar
They are cracked...did you just need certain parts off them?
This may be a dumb question, but where is the ballast? Like...if the body shop already threw my old cracked light out...is that ballast long gone?
Sorry if I sound stupid...I can follow a DIY guide like a pro but know next to nothing about this stuff if I haven't already read about it.
Old Feb 25, 2008 | 02:53 PM
Espresso's Avatar
^If they threw out your old headlights without taking out the ballast and ignitors, that might be a problem. '06+ headlights were around the $500 mark but I don't think they came with ballasts/ignitors at that price. Look to spend ~$200 on used ones. Bulbs are extras too.
Old Feb 25, 2008 | 02:56 PM
1trueG's Avatar
The ballast is a metal square/hexagon looking part on the back of the headlight. It is held in with 3 small screws I believe...So if your body shop threw out your old headlights, youre ballast would be with it...
Old Feb 25, 2008 | 04:39 PM
Boston's Avatar
[QUOTE=Nappy]
The body shop should have kept the ballast as the cost quote on the repair wouldn't have included replacing the ballast whether you were replacing the existing headlight units or upgrading to projectors.
Old Feb 25, 2008 | 04:55 PM
eminem's Avatar
Yeah i need the plug, wire, and bulb assembly for the turn signal
Old Feb 25, 2008 | 09:22 PM
ill_ace's Avatar
if you buy some 06 headlights a lot of them dont come with either ballasts or ignitors. The ignitor is attached to the back of the bulb is it is metal and it has a yellow wire screwed down. Turn the ballast and it should make a noise which means its loose and you can just pull it off. Make sure you keep that yellow wire on the ignitor. The ballast is at the bottom of the housing and is in the shape of a circle. It is connected to the ignitor. Just swap both of those into the new housing.
Old Feb 26, 2008 | 12:45 AM
phatice's Avatar
easiest thing to do, just call riverside infiniti to hook you up, but their 06 projectors don't come with ballest
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
bTanz
Oct 15, 2015 02:31 PM
derres
Aug 28, 2015 03:27 PM
newg37
Jul 26, 2015 09:32 AM
