Anyone try these H4 lights? V-LEDS HID WHITE 18 SMT
Old Mar 5, 2008 | 01:11 AM
Red_G35's Avatar
Originally Posted by BlueDevilBAMF
Oh, wow... that's Whack with a capital "W"... Do your high beams work with the regular bulbs or no? If not, jeez that's messed up.
Nope, I have four different pairs of regular H4s. None work with high beams on and the drivers side is really screwed. I'm sure IvoryGT will know.
Old Mar 5, 2008 | 01:12 AM
IvoryGT's Avatar
you probably blew a fuse. these are not meant to be used like a regular bulb. Even if it was designed to do its job like the 7443 bulbs. I found that they often have reversed polarity in some cases where you would have to bend the pin manually to make the contacts go the right way.
In any case you need to get to the fuses behind the battery to replace what you blew.l
Old Mar 5, 2008 | 01:28 AM
Red_G35's Avatar
Thanks for the info. I'll see about getting these replaced first thing tomorrow.
Old Mar 5, 2008 | 01:34 AM
Calvin's Avatar
Overglorified Altima
It is absultely no surprise that your high beams do not work with these LEDs. They are not dual filament bulbs.
Your fog light is dim? If it's still powering on, then it's unlikely that you blew a fuse.
Old Mar 5, 2008 | 01:49 AM
Red_G35's Avatar
Yes, understood that going in. Now even with dual filament bulbs the high beams do not power on.
Old Mar 5, 2008 | 12:13 PM
k@osx71's Avatar
damn that sucks man... so those crap arn't even good for show....
Old Mar 5, 2008 | 03:33 PM
IvoryGT's Avatar
they MIGHT be dual function (ie filament) but they probably have improper pins for our socket
I find the same problem with 7443 LEDs they DO work both citylight and turnsignal but the pins need to be manually bend into another position for proper connection.
Old Mar 5, 2008 | 08:04 PM
Red_G35's Avatar
thanks for the info IvoryGT. One fuse was busted, a 10amp. However there is no change... I think a relay is fried. I just dont know which relay? Any ideas?
Old Mar 5, 2008 | 08:29 PM
pjames's Avatar
sounds like something definitely shorted, check your wiring too, make sure nothing melted, as for which one, i don't know off hand, but i would check the relay box cover, usually there's an indication of what's what.
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
as25656800
Aug 9, 2015 07:25 AM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
