clear parking lights?
Old Mar 5, 2008 | 11:33 PM
thechronic's Avatar
are the high power LED's plug and play? and how much to they change the brightness of the strip? is it as good as the CCFL?
Old Mar 5, 2008 | 11:54 PM
Red_G35's Avatar
plug and play? yes. Much brighter, but CCFLs have the edge on them.
Old Mar 5, 2008 | 11:59 PM
thechronic's Avatar
ok. which LED's should i get? specifications?
Old Mar 6, 2008 | 01:20 AM
Red_G35's Avatar
high power LEDs... SMTs. Bulb size 194
Old Mar 6, 2008 | 12:03 PM
DRA-G35-ON's Avatar
signals for 03-04 coupe is 7443, and I would go CCFL for clearance strip
Old Mar 6, 2008 | 12:54 PM
thechronic's Avatar
7443? on vLED or how do i use that number? but still, no one ever answered my original question about how to change the turn signal to clear instead of orange.
Old Mar 6, 2008 | 09:47 PM
thechronic's Avatar
what about the wedge bulb for the clear corners? what are those specs?
Old Mar 6, 2008 | 10:18 PM
Red_G35's Avatar
Also 194
Old Mar 6, 2008 | 11:24 PM
thechronic's Avatar
alright, for the clearance strip in the headlight, would these bulbs work?
http://www.superbrightleds.com/specs/T13_specs.htm
Old Mar 6, 2008 | 11:35 PM
Rhino_111's Avatar
These are the ones I just purchased for clearance light, side markers, and license plate. http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Haven't received them yet but from what I hear they are a little more blue than some others which is fine because I have blue door LEDs and blue dome LEDs. Should look good for the look I am trying for.
Red_G35's Avatar
Negative. You need 194
Old Mar 6, 2008 | 11:53 PM
thechronic's Avatar
i just ordered 4 bulbs from http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
im going to put one in each clear corner, and one in each clearance strip. i am really curious to see how much of a difference it will make in the clearance strip
Old Mar 7, 2008 | 12:01 AM
Rhino_111's Avatar
Make sure to take some pics. I will as well once I get em.
Old Mar 7, 2008 | 12:48 AM
Red_G35's Avatar
this is what a single (1) SMT LED looks like
Sorry iphone pic
Old Mar 7, 2008 | 12:53 AM
  #30
IvoryGT's Avatar
the original question....you need to dremel out the turnsignal for the clear look.
like so
or like so
