Headlight Problem... need help
Old Aug 1, 2008 | 10:36 PM
elpibe's Avatar
Sometimes one of my headlights goes on and sometimes it doesn't. (the upper bulb) The number of occurrences in which the headlight fails to turn on is increasing as time goes on. I assume that the bulb is fine, because if it wasn't then it would never work, rather than off and on. Could it have something to do with being lose, the wiring or bulb? I'm not sure. Help me out if you can.
Old Aug 1, 2008 | 10:59 PM
JAYY-G35's Avatar
Try to pushing the ballast in.
Old Dec 6, 2008 | 10:30 PM
DiscretG35's Avatar
Headlights coming on inconsistently
Thanks for the answer, how do I push the ballast in? What does it look like?
DIY?
Thanks!
Old Dec 8, 2008 | 02:02 AM
sixthGear's Avatar
im having the same issue, finally burnt out. I checked the fuses and bulbs so im guessing i need a new ballast?
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
