Finished my headlights too! =)
Old Nov 10, 2008 | 12:49 AM
takashi kastl's Avatar
Took a few pictures and a video of my finished headlights tonight.
Halos coming soon..
Attached Thumbnails Finished my headlights too! =)-dsc00795.jpg   Finished my headlights too! =)-dsc00798.jpg   Finished my headlights too! =)-dsc00786.jpg   Finished my headlights too! =)-dsc00802.jpg
Old Nov 10, 2008 | 12:51 AM
da mayor's Avatar
cant wait to see them in person
Old Nov 10, 2008 | 01:03 AM
Ghayes23's Avatar
Looks pretty good. I'd like to see some daylight shots.
Old Nov 10, 2008 | 01:11 AM
I'll take some tomorrow afternoon. I do have a photo albulm of all my G pics on g35nyc.com same screen name, just click on my albulm, and theres some daytime pics there along with install pics of the HIDS,painting, baking headlights, and led installs.
Old Nov 10, 2008 | 01:52 AM
Ghayes23's Avatar
Cool. I'll check it out later. I did a Quad projector mod on my headlights over the summer so I know how much work goes into that stuff. Here is the link to mine if you feel like checking them out.
https://g35driver.com/forums/g35-cou...rojectors.html
Old Nov 10, 2008 | 01:58 AM
06g35meister's Avatar
DIY for making the corners blink?
Old Nov 10, 2008 | 02:12 AM
I'm probably going to post a DIY for customizing your own headlights/clear corners but not tonight. I'm missing a few pictures, that i need to take to make a good DIY.
Old Nov 11, 2008 | 01:19 AM
ive got more pictures on g35nyc.com Its too much of a pain in the *** to keep shrinking each pic so it fits.
Old Nov 11, 2008 | 01:51 AM
Beebo's Avatar
Diy?
Old Nov 11, 2008 | 12:51 PM
Its all really simple, its just a matter of whether or not you have the ***** to stick your headlights in the oven, and pull them apart. once there apart, spray painting is easy, biggest task was dremeling out the amber lens, after that, just sand and spray, install some led strips in the clearance and wire them to the blinker/clearance lights. Maybe ill write a DIY when i have all the pictures i need to do so.
Old Nov 11, 2008 | 12:55 PM
Foques's Avatar
how did you do the two color side marker?
i'm working on the similar project right now.
help?
Old Nov 11, 2008 | 01:02 PM
blk06x's Avatar
Looks good, would be interested in the blinking corners as well, nice work!
Old Nov 11, 2008 | 03:21 PM
help?
Clear corners are easy, if you have a dremel. Even if you have a drill, just have to be careful you dont push to hard and drill the face of the clearcorner. Once you have the 2 holes drilled, you need the LEDs. I used 4 chip luxon LEDs (super bright!) and ran a wire that i spliced to the blinker in the headlight housing. The blinker has 3 wires going to it. red green and black. black is obviously ground, and the red is the power (constant), and green is the blinker power. So i spliced the green and the black and dropped it down to the clearcorners. then i wired the red to the green and the black to the black. The end.
P.S. If you drill your clearcorners make sure you drill close to main socket. I drilled to close to the snaps that hold the clearcorner in place and ended up having to dremel out part of the bumper to make room for the led.
Id write up a DIY but im just too lazy to write this whole thing up. Someone wants to send me there headlights and clearcorners, ill do it all for 400. paint housing, leds in clearance, remove amber and add leds to the clearcorners. Takes 1 day to do.
Old Nov 11, 2008 | 04:35 PM
GreenGoblin's Avatar
The goblin resurrection
very nice both of your guys
Old Nov 11, 2008 | 09:13 PM
Foques's Avatar
Takashi thank you very much!
