PIAA Extreme White 168 Wedge Bulbs
Old Jan 2, 2009 | 04:17 PM
4drmadness's Avatar
hey guys just bought some clear corners for my sedan. i hate the yellowness of the side markers. is this what i should buy to change the lights to make them extreme white? is it a easy diy as well. thanks for your help.
http://www.g35parts.com/9083/osc/pro...97bef00d8744bc
Old Jan 2, 2009 | 04:36 PM
Mike_Deezy's Avatar
Those bulbs will work. And it's really easy, it literally take you 1-2 minutes to change them. Just pop out the clear corners, twist the harness so you separate it from the clear corners, pull the old bulb out, put the new bulb in, twist harness back into the clear corners, and snap the clear corners back onto the bumper. All done.
Old Jan 2, 2009 | 04:38 PM
4drmadness's Avatar
sweet thanks man. will buy these then
Old Jan 2, 2009 | 04:42 PM
4drmadness's Avatar
alright another question, which white lights should i get so that the yellow lights on the headlight is bright white as well. thanks
Old Jan 2, 2009 | 09:22 PM
GR8TG35's Avatar
You can try changing out the Fog (lower bulb) with an aftermarket bulb. I put in MTEC super whites, they match the stock OEM HID bulb pretty well, but are not as bright as the stock yellow bulb. I did a DIY on changing out this bulb Click Here for DIY
Old Jan 3, 2009 | 02:30 AM
4drmadness's Avatar
k where did u buy the mtec super white? the PIAA extreme white bulbs will fit the parking lights as well right?
Old Jan 3, 2009 | 09:17 AM
GR8TG35's Avatar
Sorry, I just read you have a sedan....I'm not sure where else you can use the Piaa 168 bulb on the sedan.....does it have a city light like the newer 06-07 coupes?
The Piaa's will fit the clear corners and the clearance strip on the 03-05 models
you can find the MTEC Super White bulbs on eBay, or automotivelightingusa.com
Old Sep 15, 2014 | 06:02 PM
CBOSMANG35's Avatar
Those lights look really good, I have a black 04 coupe, where did you buy the fog bulbs?also what kind of bulb did you put in that side strip?also is it an l.e.d bulb? Thanks for the info!
Old Sep 15, 2014 | 07:25 PM
Lartytiejdke3's Avatar
5 years later....
Old Sep 15, 2014 | 08:42 PM
JKL1031's Avatar
Fu** and I was reading it like it was all new.
Old Sep 15, 2014 | 09:15 PM
CBOSMANG35's Avatar
Ha me to!
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
SupermanGPS
Sep 19, 2015 01:42 PM
twentyeggs
Sep 11, 2015 03:58 PM
