HID quick question
Old Jan 15, 2009 | 04:16 PM
kennejp's Avatar
HID quick question
Hey guys I have a 04 g35 coupe 6-speed. It has the stock zenons and I was wanting to upgrade the bulb. What bulb type do I need to order? Thanks
Also is it pretty easy to just swap the bulbs?
Old Jan 15, 2009 | 04:18 PM
kennejp's Avatar
sorry I just saw the sticky but is it an easy swap? D2R bulb i see!
Old Jan 15, 2009 | 04:58 PM
yourdoinitwrong's Avatar
As long as you currently have HIDs then you just swap the bulb. It's not the easiest process in the world because you don't do it from under the hood. You have to remove the wheel well liner and do it that way. If you don't want to remove the front wheel to do it then just turn it so you have easier access to pop out the liner. The DIY below is for removing the entire lamp but it will show you how to remove the clips to get the liner out.
https://g35driver.com/forums/lightin...ple-steps.html
Jusseth
Sep 13, 2020 12:25 PM
Th611
Oct 27, 2015 03:48 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
