can anyone in the SFV help me out w/ my projectors?
Hello everybody!..
Apparently, i need a little help with my projector alignment. I received some awesome headlights from IvoryGT, however, they aren't adjusted correctly. I'm sure they're from being lugged around from the shipment. the lighting and cutoff aren't straight.
If someone is able to help me out, that would be outstanding!.. let me know if there's something we could work out. or if anyone could refer me to someone that could possibly help me out.
thanks errrbody.
thanks errrbody.
Its VERY easy to do. Search for headlight aiming. I think Redlude wrote one up. I did it off his DIY. It will take you 10 minutes...5 of which to find a spot that is straight and the right amount of feet. I aimed mine and got the cutoff perfect. Mine were also from Ivory.
thanks vette..
i just need a wall now. i tried to familiarize myself with the adjustment module/screw before i tested it to see if i was able to get something actually turning. so i think i know what i need to do. it's just now... i need a wall to fix it on.
hopefully i dont screw anything up lol i wanna get those Ivory pics up asap.. but i don't want to post up anything w/out the alignment fixed and the lights looking as they should be.
apparently my adjustment screw isn't moving my projector... it's like when you tighten a screw, and the thread get loose.
can anyone help a brotha' out? any possible fix?
First of all, verify you are actually turning the adjustment screw by accessing the screw from the rear and turning it with a 10mm wrench. If it still doesn't move, then you have likely unscrewed the projector off the adjustment screw, and will need to reopen the lights to fix it
Are these custom built projectors or a stock projector. I know he has done custom work so you may not be able to use the stock adjustment screw to level them depending how they are mounted.
Although if it feels like you unscrewed it all the way, you may have no other option than to open it up and adjust that way.
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
What is off on the aiming? Is it too high/too low/rotated?
With custom work, somethings things get caught on other parts in the light, and sometimes you've reached the limit of what can be adjusted (speaking from personal experience).
It's possible that it might have gotten loose somehow. I'm hoping not. but as i tried to adjust the up/down level there was a point where it wasn't moving at all. Light is still visible (it's not "not" shinning the road ahead of me) so i'm hoping that it hasn't disconnected the projector at all. I'm hoping the 10mm tightening will work. aside from that i'm just going to have klumzyee look at it when i drop my car off for some work.
the lights are working for me as far as lighting the road and still not blinding anyone. so i'm going to leave it as is until Eric can take a look at it. thanks for the responses.
anDross
Mar 11, 2011 03:41 PM
