Project: LED MODS (part2)
Old Feb 1, 2009 | 01:02 PM
sexyrob's Avatar
Clock taken apart
changed compass/ac lights to red, clock to white
comparison of old amber lights and new red
seat heater lights changed
trunk/vdc/dim lights changed
JDM AC control opened
Pretty lights...
Old Feb 1, 2009 | 01:07 PM
Red_G35's Avatar
very nice
Old Feb 1, 2009 | 01:11 PM
FlSHRFun's Avatar
Very nice. Great theme you got going.
Old Feb 1, 2009 | 04:24 PM
Johnmikins's Avatar
Cool, I wish I had the time or skill to do this...plus I cant solder for ish!
Old Oct 23, 2009 | 09:27 PM
ShanesG's Avatar
So sick, just curious though, how the heck did you open the clock, looks like you pulled the arms out. I opened mine from the back and ended up breaking the clock hahaha.
Also for the 4 pin plcc leds did you replace them with the plcc2 leds or did you buy seperate 4 pin ones?
Thanks!
Also did your airbag sensor light come on after you did this? mines going off and i cant get it off even after trying all the resetting, my obd-ll reader doesn't even pick up the code...
Old Oct 24, 2009 | 09:45 AM
sexyrob's Avatar
You have to desolder the 6 pins (shown in the right side of my picture) and take out the center screw. be very careful not to disturb the hair-like wires wrapped around the poles. Do not solder on them too long or it will melt the plastic they are set into.
I got two pin leds, you can see in the picture I shifted them up. I found only one connection was positive the other 3 are ground.
I just did the airbag reset procedure and it took it off, mine came on from starting the car up without the compass/clock/climate unit plugged in...
Charchar66
Dec 19, 2019 01:17 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Gabe83714
Oct 6, 2015 06:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
