Headlight Paint
Old Apr 22, 2009 | 09:38 AM
DiGil's Avatar
Headlight Paint
Not looking for a DIY, I've read them. I just wanted to know what paint people have used to paint their headlight bezels. I want a black satin finish, but I'm not sure where to find paint that can withstand the heat of baking, etc. Any suggestions?
Old Apr 22, 2009 | 09:58 AM
WhosUrBuddiee's Avatar
Try the search button.
Damn it. Where is that gif of the hand going to the New Thread button and the other hand smacks it away and takes it to the Search button?
Old Apr 22, 2009 | 10:08 AM
DiGil's Avatar
Interestingly enough, I did search. I know people have said they didn't need to use high temp paint, however most paints I see have ~120 deg as their max temp. All I'm asking for is the recommendations of people who actually did use a high temp paint, what brand was used.
Old Apr 29, 2009 | 08:13 AM
ct350g's Avatar
Krylon 'No Drip' Ultra Flat Black looks best imo ..... I have used all types of paint including 500 degree and 1200 degree high temp engine enamels on headlight bezels and the quality is definitely inferior but the durability is unmatched... those paints have ceramic in them so you get almost a textured look but will not fade or peel over time .... but I definitely recommend the Krylon ....
Old Apr 29, 2009 | 10:37 AM
visibiliti's Avatar
I recommend "Duplicolor Charcoal Bumper Coating". you can see my sig for how it turned out.
the bumper coating spray really gives the look/texture of OEM plastics. so it won't look like you took your lights apart and painted them, it will just look like they came black from teh factory if you do it right.
Old Apr 29, 2009 | 10:58 AM
JAYY-G35's Avatar
very nice set up
Old Apr 29, 2009 | 04:41 PM
DiGil's Avatar
Thanks for the tip Visibiliti, I light the lights.
Old Apr 29, 2009 | 07:01 PM
The-Dream's Avatar
I used metal primer and some random semi-glass spray paint.
Old May 7, 2009 | 09:30 AM
Iron-Mike's Avatar
I use Krylon Fusion spray paint. Its the only paint I've found that doesn't require sanding the bezels or using a primer first. Also the baking in the oven helps the paint bond to the plastic.
Old May 7, 2009 | 11:18 AM
DiGil's Avatar
Fantastic, that seems just right. Thanks Iron-Mike. Now, if I could only find someone to sell me bezels (purchased project lights with cracked bezels...arg).
Kelvin Style006
May 23, 2016 03:47 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
