HID headlights arent bright enough? wat to do
Old Apr 26, 2009 | 02:45 PM
sfgr415's Avatar
Just to clarify, sfrg415 means 50w ballasts and 4300k 50w bulbs(DL50 are best) NOT 8k
correct
Old Apr 26, 2009 | 11:32 PM
badnblk's Avatar
k but now the 4300k bulbs arent really white they kinda have a slight yellows look well atleast mine did thats why i went to the 8ks with the 50w ballasts will it still look like that or could i run maybe a 6k bulb with the 50w ballasts for a more white?
anad also ive been serching for ivory gts write up on the cutoff but no luck findin it can anyone give me a link
Old Apr 27, 2009 | 07:07 PM
IvoryGT's Avatar
go DL35 if you want whiter brighter. Works with stock ballasts. Will cost you.
Old Apr 27, 2009 | 10:23 PM
visibiliti's Avatar
ya or philips 85122CM, which will also cost u
here is the cutoff mod thread:
https://g35driver.com/forums/body-in...color-mod.html
Old Apr 28, 2009 | 10:40 AM
IvoryGT's Avatar
85122CM is dimmer just slight whiter. DL35 is actually brighter by 200lm per bulb
Old Apr 28, 2009 | 10:46 AM
visibiliti's Avatar
oh ya? nice. that's pretty close to stock then. what is the color temp of DL35?
Old Apr 28, 2009 | 10:49 AM
IvoryGT's Avatar
around 4500K and 3600lm per bulb up to 3900lm per bulb
f3594420.jpg?t=1240930332
Old May 3, 2009 | 01:36 AM
pandaboi012's Avatar
I have 8000k HID as well nd i thought it wasnt that bright when i got it so i got 8000k HID on the fog lights as well which made it hell of bright
Old May 3, 2009 | 12:12 PM
midnightGcoupe's Avatar
Fog lights help a bunch on any vehicle. I always thought a nice mix was maybe a 5000K low beams mixed with 3000k fogs. With those light spectrums mixing it provides you with great light output. I'm not saying that every car looks good with this mix, but I've seen alot of light on the ground when this is done. Good luck on your search for more light.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
