Map an Dome Light
Old May 9, 2009 | 04:32 PM
thescreensavers's Avatar
Mr.202?
Map and Dome Light (with Map DIY)
Hey, I searched and could not find what I am looking for and I am not sure exactly were this goes but...
is there a DIY on how to install a LED map/dome light?
Map Light Map Light
Dome Light Dome Light
25 bucks shipped.
Edit: I added DIY in the tittle becuse some people might search for it. Scroll down for the DIY
Thanks
Old May 9, 2009 | 04:36 PM
g35man04's Avatar
CLUB MODERATOR
you just pop off the plastic lense and it should expose the bulbs.
Old May 9, 2009 | 05:10 PM
Mr.202?
With like a flat head? which part of the light is it best place to pry it off?
Old May 9, 2009 | 05:28 PM
FlSHRFun's Avatar
Just stick a flathead screwdriver between the clear plastic and the trim and tug a lil'. If you're really scare... tape up the trim. It's not hard.
Old May 9, 2009 | 06:25 PM
g35man04's Avatar
CLUB MODERATOR
here you go bud.
stick a flat-head at the back closest to the Winshield. Pry-out alittle and it should pop out.
Second you just pull down with alittle tug and it should pop off. You should see your bulbs there. mine pictured are different because mine are all custom.
with map light turned on:
Finish just stick the clear plastic lense back up there and apply some pressure and it should snap back in place.
Old May 9, 2009 | 06:39 PM
Mr.202?
thank you g35man04
Old May 9, 2009 | 08:40 PM
g35man04's Avatar
CLUB MODERATOR
no prob man. Let me know if it works.
Old May 10, 2009 | 10:20 PM
maclarenf1's Avatar
Thanks G35man04 just the information i needed
Old May 17, 2009 | 10:57 PM
xplosive9z's Avatar
I checked on Sylvinia's website for what bulb size our door lights are (08 sedan).. it says we have DE3022... i pulled the bulbs out of the door lights and they look like license plate bulbs, not the fuse type.. i went on vleds.com and i couldnt find which one it is.. i dont want to order it, wait for them to come and they dont end up fitting..
does anyone know which is the correct bulb on vleds?
Old Feb 23, 2010 | 09:55 PM
twalls's Avatar
CLUB MODERATOR
I know this is an old thread, but I just ordered some.. I got the same bulbs for the door as the map lights. here's the ones I got.. Halo Icis Blues
Old Mar 5, 2010 | 03:32 PM
angel_eclipse98's Avatar
hey man where did you get ur blue dome lighting? And for how much? Thanks a lot
Old Mar 12, 2010 | 01:58 AM
optimus187's Avatar
g35man04 you are the bomb. I've been looking for this for days and I finally will be able to do this.
Old Mar 12, 2010 | 02:12 AM
Mr.202?
bah wish I could fix the tittle lol
any how, thanks again g35man04 it was simple but back then I had no idea
Old Mar 12, 2010 | 04:58 PM
twalls's Avatar
CLUB MODERATOR
shoot M-Motorsports a PM.. He's a vendor on here.. You want the Icis Blue LEDs.. It's a direct replacement for the bulb that's currently up there. I got them for the door lights too. I got a lot of stuff at the same time, so don't know exactly how much those were, plus I live in Texas, so Tax was in there too..
Old Mar 12, 2010 | 08:46 PM
Bestswat's Avatar
im not sure why there is a thread on this its really that easy.
