Third Brake Light LED is out
Old May 12, 2009 | 12:20 AM
Wannabe6MT's Avatar
-MN G Crew-
My sisters fiance notified me the other day that one of the LEDs in my third brake light is out. Checked it out, and sure enough the middle one is kaput.
Are these hard to replace or should i take it to the dealer? How much do they charge to change the bulb?
Old May 12, 2009 | 12:53 AM
Beebo's Avatar
you have to buy new from the dealer or ask someone that has a spoiler if you can buy their third brake light
Old May 12, 2009 | 12:59 AM
Jeff92se's Avatar
Red Card Crew
What beebo said and btw, the right screw is a major pain in the **** to get at if you try to get at it from the trunk. AMHIK
Old May 12, 2009 | 01:02 AM
Beebo's Avatar
Janik its not had pull out the housing (i guess you sedan guys have screws holding the housing) disconnect the light remove the LED strip and replace with the used one you buy.
Old May 12, 2009 | 02:44 AM
tengtengvn's Avatar
Last time I checked, they charge ~150 for parts and 150+ for labor.
I tried that before, you can move it nowhere even after you unscrew it.
Old May 12, 2009 | 11:08 PM
Wannabe6MT's Avatar
-MN G Crew-
Jeff did you replace yours?
Called today, its like $226 to replace. Yuck. Im gonna hope a used one pops up.
Looked at it from the trunk, really looks like a pain in the ***.
Old May 12, 2009 | 11:22 PM
Beebo's Avatar
Post a thread in the WTB section, lighting section and sedan section of the forum asking if anyone will sell theirs to you for like 100, that sounds far
Old May 12, 2009 | 11:27 PM
FlSHRFun's Avatar
Dang, $226? I noticed this happened on my girlfriend's G sedan. One of her LEDs is out. Don't want her to have to shell out $200 on one LED.
Jeff92se's Avatar
Red Card Crew
Yes and yes it's a pain. Actually if you are willing to drill a hole in you deck lid, it would make the process alot easier (the right side screw is a royal pain). I think the std method is to take apart your rear deck panel but that entails taking the rear seats out.
I have NO idea why there is a big hole in the deck sheet metal yet it's just inches from being large enough to reach the right side screw.
Old May 13, 2009 | 12:26 AM
Wannabe6MT's Avatar
-MN G Crew-
I might just leave it. This sounds like a royal PITA to change just for 1 LED.
Old May 13, 2009 | 12:54 PM
Beebo's Avatar
only one LED is out?
Old May 14, 2009 | 12:40 AM
Wannabe6MT's Avatar
-MN G Crew-
Yes right in the middle. Looks ****ty as hell, but not $226 worth of ****ty.
Old May 14, 2009 | 11:07 AM
MidnightG35X's Avatar
If you have the light out, how hard is it to open up and just replace the burnt out LED? If you can solder, probably not terribly hard (and cheap).
Old May 14, 2009 | 02:15 PM
WILLIE BEANS's Avatar
My third brake light goes on whenever it feels like it ..
Sometimes it works sometimes it doesnt ..
I guess il check to see if the connection is loose ..
Old May 14, 2009 | 05:38 PM
tengtengvn's Avatar
It's the wires in the back the LED light. If you can get your hand in there and touch it you will see it turn on again.
