G35 Sedan 2004 Halo/Angel Eyes Install... Help!!
Aug 12, 2009 | 04:00 AM
Ok, I just got a good deal on a halo kit from eBay. I know how to get my headlights out and to bake it on 200*F for 15 minutes for the glue for the lenses, but whats the best way to secure the actual halo ring to the housing?? Also can anyone help me with the wiring as my kit is not plug'n'play. I want to use the running lights, like the parking light in the side of the headlight housing, so I can switch it on to run in the daytime or turn it off from the factory headlight switch. PLEASE HELP! Thanks so Much!
-DBroncos
Reply 0
Aug 12, 2009 | 08:05 AM
you can use a an epoxy that you will have to mix together. It should be clear . Advance Performance sells these kits for 200 and brings the adhesive. They say to use a bit of it in a triangle pattern inside the headlight .
Now the wiring is easy all you have to do is tap into the parking light using a volt meter to see which wire is parking lights. Its not much to it. You already took the housing off and thats the hard part,lol
Lets us know how it went.
Reply 0
Aug 12, 2009 | 11:57 AM
Would there be any harm in using a complete circle of epoxy behind the halo? and I take it u put the epoxy directly on to the halo ring?
Reply 0
