Fog Light HID Conversion
Old Aug 12, 2009 | 12:47 PM
anadich961's Avatar
Ok.. i've been searching for a while and its just confusing me because I cant find a consistent answer to my question. I recently put a 10000k hid bulb in my 04 g35 coupe for the low beams. I want to match the fog lights by putting in a conversion kit. do i need to put in a bixenon kit because the bulb is both high beam and fog light? Or does the headlight switch from fog to high beam some other way and I just need to put in a regular kit? Also, does anyone know if the stock ballast is 35w or 55w, so I can get a matching kit? Thank you so much!
Old Aug 12, 2009 | 01:28 PM
IrockAG35's Avatar
Ohio G Club moderator
i dont know alot about converting the fogs to HID but im thinking youll need another ballast for sure you may be able to hardwire another ballast into the existing one meaning you wouldnt need an HID kit...someone on here has done it..look up the quad projector kits on here the wiring setup should be similar
Old Aug 13, 2009 | 11:30 PM
slvrg05's Avatar
sub bro u dont need a bixenon bulbs for the fogs, you only need h4/9003 bulbs . You definitley need a seperate kit. you have a switch that just turns on the fogs when u click it forward so it wont turn on the high beams cuz you already have them on the low beams.
let me know if this helps.
Old Aug 17, 2009 | 10:55 AM
anadich961's Avatar
ok so i get that.. and thanks for the help...
now does anyone know if the stock hid's are 35w or 55w?
Old Aug 17, 2009 | 11:15 AM
slvrg05's Avatar
its 35 watt oem. I think we all agree 55watts is definitley better.
Old Aug 17, 2009 | 11:21 AM
Paratus Fahren's Avatar
From: Sacramento, California and Flower Mound, Texas
Agreed!!!
Jusseth
Sep 13, 2020 12:25 PM
zoop425
Mar 29, 2016 05:51 PM
Freddy07g35
Sep 17, 2015 08:53 PM
LARA_G35
Aug 21, 2015 12:52 PM
attarday
Jul 15, 2015 04:03 PM
