Custom LED headlights
Old Sep 22, 2009 | 02:18 AM
greek2003g35's Avatar
but what did u use to actually hold the LEDs in place? did u glue them down?
Old Sep 22, 2009 | 02:36 AM
alexcaro's Avatar
I try to avoid glues, as some glues that are exposed to heat can cause a mixture of haze inside your headlight. I haved used RTV glue, as it appears to be safe.
For me it depends on the LEDS I use.
I actually dremel a hole and connect them to a circuit through the other side which holds them in tight once they are soldered.
Depending how they are connected (series or parallel, with individual resistors or in groups) there are some LEDS that can be placed there in a premade strip. If a problem would occur, I would rather replace one bad LED instead of having to replace a strip and having them all go out.
Old Sep 22, 2009 | 02:41 AM
yea i think im gonna try and order a strip from VLEDS.com because that seems to be the easier w\way of doing it and not having to mess with resistors since they are already premade with them but thanks for your help.. hopefully all goes well
Old Sep 22, 2009 | 02:48 AM
alexcaro's Avatar
Sure, good luck on your project.
Old Mar 8, 2010 | 06:04 PM
dann1313's Avatar
where did you get the clear reflector from??
please pm me i cant find then n e where
Old Mar 8, 2010 | 06:56 PM
4DGS's Avatar
^the turn indicator?
I have some. You need to retrofit it, but it's not that hard.
Old Mar 13, 2010 | 12:43 PM
bmpnride's Avatar
Open up lights... Drill holes for the LEDS... Inserts LEDs and glue... Wire them up as you see fit.... Seal lights back up... DOne..
Old Apr 25, 2010 | 11:45 PM
TIAN's Avatar
Hold The Line
Bump. Alright, since I'm getting my whole car custom painted with extra goodies I figured I'd do my HLs as well to complete the car. My headlights will look exactly like this paint wise. I'm having a hard time figuring out exactly how to get the side clearance LEDs in and where to get them. Can anyone please point me in the right direction?
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
alessandro
Oct 8, 2015 09:29 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
twentyeggs
Sep 11, 2015 03:58 PM
