need help on kptech foglight module
Old Sep 25, 2009 | 02:48 PM
KPierson's Avatar
The wires you need are in the big 40 pin plug.
You lost me talking about the yellow wire on the relay switch - the only yellow wire should be the one on the module itself (the little black box with the blue LED).
Old Sep 25, 2009 | 04:59 PM
vietster's Avatar
can you post the wire numbers for the relay like u did above. i disconnected and reconnected all the wire for the bcm and still the blue led light stays on constantly
Old Sep 25, 2009 | 05:52 PM
KPierson's Avatar
The relay wiring has nothing to do with the blue LED - you need get that part working correctly before you even worry about the relay wiring.
To get the LED to turn on/off correctly the yellow, black, blue, and green wires of the module must be connected properly.
Does the blue LED turn off when you disconnect the blue and green wires?
Old Sep 25, 2009 | 06:25 PM
vietster's Avatar
have to try that later, but i connected all the wires according to the diagram, even had a buddy look at it to make sure the wires are connected right. on a side note, i do hear a clickin sound when i turn on the fog light switch on and off.
Old Sep 25, 2009 | 07:16 PM
KPierson's Avatar
Where is the clicking noise coming from?
Old Sep 25, 2009 | 07:43 PM
vietster's Avatar
sounds like its coming from the KP relay/battery area
Old Sep 25, 2009 | 07:58 PM
KPierson's Avatar
With the headlights off do you still hear the clicking when you turn the fog lights on and off? I'm curious if is the KPtech relay or the OEM fog light relay that you are hearing.
Old Sep 26, 2009 | 03:50 AM
vietster's Avatar
no you can only hear it if the headlight is on
Old Sep 26, 2009 | 08:18 AM
KPierson's Avatar
Then that is the OEM foglight relay (it is in the battery area).
Where did you connect the KPtech yellow wire? How about the black wire?
I still think you have at least one of those first 4 wires hooked up incorrectly (either the yellow, black, green, or blue).
Old Sep 26, 2009 | 12:05 PM
vietster's Avatar
the yellow is hooked up to pin 11, black is grounded to the chasis, green to pin #3, and blue to pin #32
Old Sep 26, 2009 | 01:27 PM
KPierson's Avatar
Have you tried disconnecting the blue and green wires to see if the light turns off? Theoretically, if you disconnect either wire the LED should turn off.
Old Sep 26, 2009 | 06:23 PM
vietster's Avatar
just tried it and the led light still stays on. i disconnected both the green and blue wires
Old Sep 28, 2009 | 10:10 AM
KPierson's Avatar
Next, keep the blue and green wires disconnected, and unplug the relay from the relay socket (to prevent any backfeeding through the coil).
I'm still trying to figure out what the red wires on the dimmer do to determine if hooking the yellow wire to the dimmer could have damaged the hardware. I can't find any references to the dimmer in the service manual.
Old Sep 28, 2009 | 10:24 AM
KPierson's Avatar
Originally Posted by vietster
finally figured it out, but there still a couple problems. First of all the relay you sent me the colored wires(blue,green,red and white) didnt match at all, i had to pull apart the relays to see which wires were actually 87, 30, 87A, etc. i figured since you mass produced these the wire color code would match what at we are supposed to be matching up according to your directions, so that was very frustrating. now the problem is that these fogs have to be manually turned off and the radio turns on and off with the ignition turned off
So does this mean it is working?
When did you purchase the module? We have updated our installation instructions to completely get rid of color references on the relay. We don't manufacture the relay harness, we purchase them from another vendor and sometimes the wire colors do change. We recomend ALWAYS going by the pin number.
You may want to download the latest installation manual - http://www.kptechnologies.com/docs/M...stallation.pdf
Pay close attention to the wiring requirements for the relay (Pin 86). You MUST use a switched power source, NOT a constant 12vdc. This should clear up the "manually shutting the lights off" issue. If you don't want to rewire the relay you can made a small modification to the circuit board (usually easier then rewiring - http://www.kptechnologies.com/forums...php?f=30&t=488
Old Sep 28, 2009 | 11:48 AM
  #30
vietster's Avatar
yeah i forgot about the update on the 12v constant once i do that im sure that will solve the problems. i was just following accord freaks directions so i didnt think i needed to double check the wiring colors on the relays. but it is working and thanks for your help KP
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
bigmike
Sep 17, 2015 01:58 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
miata007
Aug 17, 2015 04:36 PM
as25656800
Aug 9, 2015 07:25 AM
