HID problem
Old Nov 23, 2009 | 07:25 PM
CreativeDesignZ's Avatar
HID problem
I switched over to 06-07 projectors, last night i installed some 6000k HID's to replace the 4300k OEM phillips bulbs. Everything worked fine throughout the entire night. While i was driving home i noticed my drivers side darker than the other. Low and behold my light was out. I would turn the lights on and off, it would flicker but not completely power on. I have to do it about 5-10 times then it will power back on, and then turn completely off. If there is anyone who has experienced the same issue would you please be able to give me some guidance or assistance in this matter? I really dont want to be driving at night with one headlight out. Thanks!!!
Old Nov 24, 2009 | 12:39 AM
Morovasa's Avatar
My buddy is having the same problem with his car ... he installed 6K HID's in his 08 Audi TT.
He was told that he needs to add a relay I believe to the setup.. Basically since they use less power, if the wires think the light is burnt out they will stop sending power to the bulb. So you need some relay or something that holds the power and start up / turn on and keeps the constant flow going.
Hope I am explaining this right.. (its what my buddy was telling me earlier tonight)
Old Nov 24, 2009 | 01:28 AM
-LangsurG35-'s Avatar
seems like to me that your ballast is about to go bad
Old Nov 24, 2009 | 01:29 AM
speedracerg35's Avatar
ballast or ignitor^. one or the other.
Old Nov 24, 2009 | 11:25 AM
BloodlineG's Avatar
what part is the ballast mine is doing this too :/ pics?
Old Nov 27, 2009 | 12:06 PM
ive noticed it only happens after about 30 minutes of driving. its only happened twice so far and seems to be happening less frequently now. ill just have to keep an eye on it
Old Nov 27, 2009 | 11:48 PM
IGTAUTO's Avatar
I dont know why you would first think anything else is wrong other than the new bulbs you put in? The OEM bulbs you replaced are the best quality bulbs on the market, then you go and replace it with something cost less than 5 dollars to make. You get what you paid for. Go with phillips 6000K and see if that happens.
Old Nov 30, 2009 | 12:17 PM
the bulbs are the first thing that i thought was the problem IGT, replacements are being sent out to me as we speak. if its not this then its the ballast for sure.
Kelvin Style006
May 23, 2016 03:47 AM
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
twentyeggs
Sep 11, 2015 03:58 PM
