custom led headlight project
Old Jan 10, 2010 | 10:44 PM
the_sedan's Avatar
so here's the ......i have a set of 06-07 headlights apart. i've seen a post some time ago with someone who did an awesome set of headlights but i cant seem to find any post with them anymore. i'm going to paint match the housing to the my OB coupe. instead of doing led's down the non-existant clearance strip....i'm goin to run led's on the inside. like that one person did. he even had a "x" in the marker lens. if anyone can find this post...please help me out cuz i've searched it up with no success. so im gonna run 7 white led's up the housing above the marker lens area. and i want to run either a red halo or red led ring around the projector lens.....and im unsure if i want to use another one elsewhere. ive looked at that oznium site for the strips and individual led's. any ideas or suggestions would be appreciated. thanx
Old Jan 10, 2010 | 10:50 PM
the_sedan's Avatar
oops...start of the project pix.
Attached Thumbnails custom led headlight project-100_1220.jpg   custom led headlight project-100_1221.jpg   custom led headlight project-100_1222.jpg
Old Jan 10, 2010 | 11:06 PM
Frankieg35's Avatar
Look up IGT.. They specialize in headlight modification..
Old Jan 10, 2010 | 11:39 PM
cc_brandon's Avatar
I remember seeing that post with the X in LEDs. I'll see if I can find it again.
IGT doesn't do headlights anymore I don't think.
Old Jan 10, 2010 | 11:49 PM
elayman's Avatar
here you go
https://g35driver.com/forums/lightin...exylights.html
Old Jan 11, 2010 | 10:10 AM
the_sedan's Avatar
yup thats it. thanx. i love the red accent paint but im going all black in my housing. i might leave the piece in front of the low beam silver but idk yet. im going to either run a red halo or led strip around the projector with the leds going up the inside. idk if i wanna put another halo anywhere else yet.......ideas? and im doing all this myself other than having my buddy paint match the housing for me. thanx again.
Old Jan 11, 2010 | 10:13 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
IIRC he's not doing lights anymore, mainly just CF work.
Old Jan 12, 2010 | 03:54 PM
bmpnride's Avatar
I used the silicone LED strips from oznium in my setup. It all depends on what look you want to achieve. SOme like the lights facing forward where I opted to have them aimed at the lens so they create a nice ring effect on it. Also, the number of lights in the projector will determine what it will look like. The more light there are the more it will flood that area with light.
Old Jan 12, 2010 | 09:01 PM
the_sedan's Avatar
im gonna have like 9 3mm led's running up the inside and im debating on whether i wanna run white or red led strips around the projector lens for the same effect you got goin on. just give it a lil demonic look since the housing will be blacked out. i believe i will have it wired up to the marker light, or is there a better way to wire it up seperately??
Old Jan 13, 2010 | 02:04 AM
laksjd84's Avatar
dont do anything red in your headlight, unless its something you can turn it off or cannot be seen once the low beams are on (within projector lens). you will get pulled over and fined.
Old Jan 13, 2010 | 08:19 AM
the_sedan's Avatar
yeah that was my next thought. im gonna be doin what bmpnride did and do the led strip facing the inside so it shines on the lens. i'll prolly just stick with white to avoid any issues cuz i dont wanna be addin/runnin wires and switches in this car.
Old Jan 13, 2010 | 01:15 PM
elayman's Avatar
^ you will probably wan't to run a relay or switch to at least the halo b/c I don't think the leds will last with all of the heat from the projector, so you'll want to switch them off when the headlight goes on. Someone can probably chime in with experience
Old Jan 13, 2010 | 02:57 PM
the_sedan's Avatar
yeah that would make sense to have it shut off when the lights are on.
Old Jan 13, 2010 | 03:11 PM
bmpnride's Avatar
Depending on what strips you use, they could be left on all the time with the projectors. I have my angel eyes and my side strip wired separately to switches inside my car. The angel eyes are not visible when the projectors are on so I turn those off. There are many options when it comes to LEDs. What size LEDs are you gonna use for the housing? I would suggest at least 5mm since the 3mm are pretty small and not as bright.
Old Jan 13, 2010 | 11:20 PM
the_sedan's Avatar
i was thinking of doing 3mm but it wont be no problem to run 5mm since i haven't ordered any led's yet. and i was thinking of the flexible led strips from oznium to go around the projector lens.
