HID headlight help
Old Jan 19, 2010 | 06:48 AM
bknewtype's Avatar
HID headlight help
hey guys im experiencing a problem with my left headlight. my problem is that the left HID bulb wont turn on. i tried 3 other bulbs and none of them worked, so i know its not the bulbs problem. im afriad it might be the ballast. everything else works ( turn signals, side markers, clearance strip) only the left HID bulb wont turn on. is there a way to check if the ballast went? or could there be a more simple solution to the problem? my headlights are 03. thanks in advance.
edit 4/16
bumping this up. i replaced my ballast, and my hid's worked fine for about 2 months, and now its doing the same thing again, so im pretty sure its not the ballast since my fog lights are lit too. my drl/led above the foglight is also not working anymore. anyone have any ideas on where to check? i also checked all the fuses.
Old Jan 19, 2010 | 07:02 AM
slvrg05's Avatar
the best way is take out the right bulb and install it on the left where the problem is and if doesnt work the its ur ballasts. I think thats the best way.
Old Jan 19, 2010 | 07:08 AM
bknewtype's Avatar
pretty sure its not the bulbs, they were just bought about 2 weeks ago. if it is my ballast, can i just purchase a HID kit and use that ballast to replace the bad one? or do i need the OEM ballast to b working to fuel power into the new ballast? i never done a HID kit before so i dont know how it works, thanks.
Old Apr 16, 2010 | 06:44 AM
bknewtype's Avatar
Old Apr 17, 2010 | 10:24 PM
dave's Avatar
Maybe you are getting water in there somehow and it is shorting things out?
Old Apr 18, 2010 | 11:02 AM
EnJoiLuv's Avatar
Id like to know about this too! I dont want to use up too much money on OEM ballasts and + the oem ballasts w/ aftermarket bulbs are really weak! Can i just buy a conversion kit and use the ballast that came with the kit instead?
Old Apr 18, 2010 | 04:01 PM
davidxu's Avatar
the fog lights are not part of the ballast. The ballast only powers the HID bulb.
Old Apr 18, 2010 | 05:07 PM
rhoward15's Avatar
just take out the manual
thats what i did
Old Apr 19, 2010 | 06:38 AM
bknewtype's Avatar
before i changed my ballast, i had a diff set of headlights and it did the exact same thing, and same side
you can, but its a pain because youll need to drill new holes to place the ballast somewhere, and its nto worth it imo.
thanks for that clarification
i am still having this problem. some people suggested using a relay. anyone have any write ups on how to DIY?
Old Apr 19, 2010 | 12:00 PM
slvrg05's Avatar
u might be having a short somewhere, a cut wire tat is touching something and it might not let it turn on.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
