Will these work for parking/city light LEDs?
Old Feb 5, 2010 | 08:49 PM
xxkylexx's Avatar
Will these work for parking/city light replacements (06 coupe)?
http://cgi.ebay.com/ebaymotors/2x-19...item2a04902e5a
Old Feb 5, 2010 | 08:53 PM
Calvin's Avatar
Overglorified Altima
They'll fit the socket, but I don't think they'll fit through the hole.
Old Feb 6, 2010 | 12:22 AM
xxkylexx's Avatar
Anyone know where I can find a good LED for the parking light on a 06 coupe? I've found loads of 168's on eBay, but unsure if they will fit in the headlight hole like calvin mentioned.
Old Feb 6, 2010 | 12:26 AM
TofuProductions's Avatar
wont fit. tried them before.
I forgot where I got my led city lights.. but they are fairly bright, same with my license plate and sidemarker lights. They shine pure white too, not that blue/white look.
Old Feb 6, 2010 | 12:54 AM
xxkylexx's Avatar
Would something like these work?
http://cgi.ebay.com/2-Bulbs-Pair-White-194-168-T10-SMD-SMT-4-LED-Light-NEW_W0QQitemZ280448395385QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item414c06e879
They seem pretty close to the Halo ones being sold here on the forums as Parking lights.
https://g35driver.com/forums/accesso...plate-led.html
Old Feb 6, 2010 | 01:03 AM
elayman's Avatar
I've got 21led bulbs in mine.. looks like the ones in the OP from v-leds. fit fine
Old Feb 6, 2010 | 11:51 AM
xxkylexx's Avatar
Are you using 06+ headlights?
Old Feb 6, 2010 | 11:56 AM
WILLIE BEANS's Avatar
these are the ones im using .. on side markers and city lights..
hope it helps ..
http://www.superbrightleds.com/cgi-b...ini-wedge.html
WLED Miniature Wedge Base bulbs
T3-1/4 (#194/168) filament bulbs found in many automobile and water craft applications. Built in current limiting resistor and diode to protect the LED from reversed polarity installation. 12 Volt DC operation.
Replaces: 194, 158, 168, 12256, 12961
WLED-x5
1 High Flux LED & 4 x 3mm Radially Mounted LEDs, 220 degree beam
Available in Cool White - 12 lumen @ 8000K Natural White - 11 lumen @ 4500K Warm White - 10 lumen @ 3300K Blue Green Red Amber UV-Blacklight
p.s. the ones you posted are good .. but they are too long ..
Old Feb 6, 2010 | 12:07 PM
xxkylexx's Avatar
hope it helps ..
WLED-x5
From the specs link below it looks like the ones you are using are 14mm in width. If those fit through the hole, then I assume the original ones would too since they are only 11.5 mm at most. So I'll look for some a bit shorter. You are using 06+ coupe headlights right?
http://www.superbrightleds.com/cgi-b...%2FWLED-x5.htm
Old Feb 6, 2010 | 01:07 PM
nope .. ive got a 2003.5 sedan ..
but im sure theyl fit a coupe as well ..
Old Feb 14, 2010 | 05:07 PM
0-60Motorsports's Avatar
Any pics fellas? I just installed 6k xenon bulbs and was wondering if you guys can point me in the direction of matching parking light bulbs please
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
attarday
Jul 15, 2015 04:03 PM
