How to aim headlights?
Old Mar 10, 2010 | 01:17 PM
acr's Avatar
acr
I swapped headlights yesterday, and now mine are adjusted too high. How do I go about aiming the lights? I'm not talking about the specifications - these can be easily found online. I'm talking about the bolts that must be tightened/loosened in order to aim our headlights. I found instructions for 06+ coupes, but they didn't give me anything. I have an 05 G35x.
Old Mar 10, 2010 | 01:58 PM
azt108's Avatar
Look through this:
http://psedog.com/cars/fsm/g35/sedan/2003/lt.pdf
Old Mar 10, 2010 | 02:05 PM
acr's Avatar
acr
Originally Posted by azt108
you the man.
Old Mar 10, 2010 | 02:15 PM
azt108's Avatar
I know.
Old Mar 10, 2010 | 02:19 PM
acr's Avatar
acr
I think I've found the adjusters. Is a special tool required? It looks like it would have to be a really long screwdriver.
Old Mar 10, 2010 | 02:46 PM
nghiars's Avatar
just a liong screwdriver
Old Mar 10, 2010 | 02:47 PM
OKStateG35's Avatar
I adjusted mine with a long phillips head screwdriver. The end locks into the gear and turns it.
Old Mar 10, 2010 | 03:05 PM
azt108's Avatar
I recently installed new headlights, does anyone know if I should be adjusting them?
Old Mar 10, 2010 | 03:15 PM
acr's Avatar
acr
I tried this, but the phillips head wouldn't turn the gear. It just slipped. There was another adjuster-looking thing that I found near the top of the headlight, but it had what looked to be a hex head in there. I'm thinking I should just take the car to a shop to get professionally aimed. The dealer wants $60, no shot
Old Mar 10, 2010 | 03:16 PM
acr's Avatar
acr
probably.
Old Mar 10, 2010 | 03:28 PM
OKStateG35's Avatar
This is probably the same thread you already looked at, but I'm pretty sure the gear you are looking for is the same. Try a different screwdriver. Mine worked first try, no problem. Either your screwdriver is too big/small or your adjustment gears are stripped out.
https://g35driver.com/forums/body-in...rojectors.html
Old Dec 23, 2010 | 12:05 PM
acr's Avatar
acr
bringing back my old thread instead of starting a new one. Is there any adjustment for the lateral aiming of the headlights? My headlights are both pointed left a bit, which is annoying and would blind oncoming traffic.
EDIT:
according to the shop manual, there should be a second adjustment lower on the headlights. I bought a long (10" or so) screwdriver to adjust the vertical aim of the lights, which worked. I can't find the adjusting screw for the lateral adjustment, though.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
