Need help on fog light fuse
Old Mar 17, 2010 | 03:41 AM
lcysimon's Avatar
I have a 06 6mt coupe and I just installed my fog lights last week.
It was all working until the passenger side one went out today.
They were the $30 Halo brand ones too...
So I tested and placed 2 other working bulbs on to the wire and it didn't work.
So I guess it's the fuse?
Everything works, including my 6k D2s HID, Polarg Driving LED and even the passenger side fog light.
Does anyone know where the fuse is located for the passenger side?
I checked the fuse box next to the clutch and the battery and couldn't find it.
Thanks in advance for your help!
Old Mar 17, 2010 | 10:24 AM
herrschaft's Avatar
There's a third fuse box behind the battery.
Old Mar 17, 2010 | 10:29 AM
1blualti's Avatar
sorry to threadjack...but ive been having this same problem for months now but could never find the fuse for it...so there's a fuse box in front of the battery and also one behind it? does the battery need to be removed to get to it or something b/c ive never seen it...
Old Mar 17, 2010 | 02:39 PM
herrschaft's Avatar
No, you just have to remove the section of plastic directly behind the battery. Its only a few plastic clips that hold it on there.
Old Mar 18, 2010 | 02:21 AM
lcysimon's Avatar
Is this for automatic only or?
I looked behind the battery and couldn't locate anything.
Do I have to remove the battery?
I looked up the owner's manual and it says that there are only 2 fuse boxes.
One in the Engine Bay in front of the battery and other inside the car by the clutch.
Please help!
Old Mar 18, 2010 | 06:10 PM
twalls's Avatar
CLUB MODERATOR
I had to remove my battery to get to it.. was replacing the side marker LEDs and the fuse blew.. It's right behind the battery and yes, I had to remove the battery to get to it. If there's some trick to that, I don't know it.. But got to it easily once the battery was removed, switched it out, and everything's working fine now.
Old Feb 12, 2012 | 05:58 PM
dvsmeth0dz's Avatar
Would unplugging the fog light while it was turned on blow the fuse? Sorry for bringing back such an old thread.
Jusseth
Sep 13, 2020 12:25 PM
zoop425
Mar 29, 2016 05:51 PM
Freddy07g35
Sep 17, 2015 08:53 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
