Side Markers not working
Old Apr 30, 2010 | 11:40 PM
ldg870's Avatar
I was going to do the side marker blinker MOD. I didn't even notice my side markers were even lights, I thought they were reflectors. They never come on. Not with the parking lights, headlights, blinkers, hazard. They have a bulb. It is a 2006 5AT coupe. Is this normal? Should I just go ahead with the MOD?
Old May 1, 2010 | 02:07 PM
Marinelli Motorsports's Avatar
The bulbs should be on when your lights are on. If not either you have burnt out bulbs or a blown fuse.
Old May 3, 2010 | 08:10 PM
ldg870's Avatar
OK. I checked all the fuses in the 3 fuse boxes. Even the one behind the battery. They are all good. The bulbs are good. I took it in a couple months ago for the headlight recall. I'm not sure if they were working before that. If I go with the MOD. Do you think that might fix my problem.
Old May 3, 2010 | 09:13 PM
the_sedan's Avatar
change the bulbs? ive never seen them be out cuz of a fuse? if that was the case, all the markers would be out. i'd be checking wires first. getting power? ground?
Old May 9, 2010 | 02:31 AM
ldg870's Avatar
I finally got around to check voltage. I have 2 burned out bulbs. It probably happened at the dealer when the headlights were replaced. Voltage checks out good, just blown bulbs. Thanks for the help.
Old Aug 16, 2022 | 05:45 PM
Pogue Mahone's Avatar
G35 Coupe
How do you check the voltage of the wires and the bulbs?
Old Aug 19, 2022 | 10:54 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Turn your DMM to DC volts, if it's not an auto ranging meter then select something like 20 DCV. Turn on your headlights, put one probe into the socket on 1 pin, put the other probe into the socket on the other pin.
Don't cross the probes or you will blow a fuse.
Your meter should read 12VDC, if it doesn't then you do not have power to the socket and need to troubleshoot the issue.
yassy
Aug 3, 2015 12:24 AM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
attarday
Jul 15, 2015 04:03 PM
