I just bought a 6000k hid h1 conversion kit and i need have some questions about the install. I have couldnt find a diy on how to do it. I know u have to drill a hole in the back of the headlight but i dont know how to wire up the hid bulbs to the stock wiring. there is a green wire that goes directly to the bulb that i am guessing is the positive, and there is a black one which im guessing is the negative. am i going to have to cut both of those wires or is there another way to connect them. keep in mind i have very minimal electrical experience. thanks
the wires going to the bulb go to the ballast not the stock wiring the other wires on the ballast go to the original 2 wires from the HL
does anyone know if there is a diy for puttin these in it would help a lot. and if not can someone just offer some help on how they installed theirs
There are universal instructions + what i gave you all over the internet . It is the simplest thing you can do . Do you have a kit made for the foglight plug or just red/black wire . If the first jst plug it in if not the red to the bulb your replacings color wire and black to the hl black wire . done.
