03-05 headlight + clear corner question
Old Jun 29, 2011 | 03:00 PM
hdmark's Avatar
I recently replaced my headlight bulbs with 6000k and it looks great. (coupe so its stock hid). i want to get the highbeam/foglights to match.
what confuses me is how that works.. is it one bulb in there and the front reflector just shifts? also, they are not hid's right? at least stock. they can take simple leds?
if so, do i only need to find 6000k led's that are HB2? and then in that case, do they work as well as the stock , im assuming, halogens?
Thanks for the help in advance!
Old Jun 30, 2011 | 12:40 AM
Mark2K8's Avatar
The fogs/hi beams are H4s, which are dual filament. Thats how they can be fogs and hi-beams at the same time.
Old Jun 30, 2011 | 09:52 AM
hdmark's Avatar
okay thanks! Would you be able to suggest any that are 6000k? or would led's with 6000k color work?
Old Jun 30, 2011 | 10:05 AM
hdmark's Avatar
would this kit work. I guess it is an HID conversion
http://cgi.ebay.com/ebaymotors/1X-HI...Q5fAccessories
Old Jun 30, 2011 | 10:31 AM
Mark2K8's Avatar
I dont know about LEDs/how they work, but I'd go with the legit kits instead of buying those plug and play bulbs from ebay. Cause most of the time the advertised temperature is never what it is (and each seller is different too. For e.x. i bought "5000k hyper white" fog replacement and they turned out yellowish)
So go for the kit (and yeah that kit will work)
Old Jun 30, 2011 | 10:38 AM
hdmark's Avatar
okay thanks alot ! I have a friend ripping them apart to install halo's (i really like them lol), il ahve him do that too . Installing those HID's arent hard right?
Old Jul 10, 2011 | 04:51 PM
cthrulies's Avatar
If you want an H4 HID (Fog light/High Beam) 6000k Kit take a look at www.vleds.com. Look at www.luminicsusa.com for an H4 halogen bulb (Fog light/High Beam) 6000K called Luminics Krypton Pure Blue H4. BTW, LEDs do not have enough light intensity (measured in lumens) to project light on the road surface, I would not use LEDs as "driving lights".
mbe093
Lights
Oct 2, 2016 11:09 PM
underworld
Aug 6, 2015 01:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
Tylerttn
Jul 14, 2015 10:11 PM
