Took lowbeam bulb out of driver side now passenger side no lights come on???
Old Aug 13, 2011 | 05:05 PM
04InfinG35's Avatar
Hey Guys,
I need some help. My driver side low beam bulb was on the verge of going bad and flickering. I went to replace it and had bought the wrong type bulb to replace it with. I kept the bad bulb out and ordered a replacement of the right model bulb online. That night I drove the car and no lights were lighting up on the passenger side. I could turn the high beams on(both sides still working) and had to drive like that but no side marker, no low beam(which had no issues prior to taking the other bulb out). I got the low beam bulb and put it in the driver side and it works as well as every other light on the drivers side but still nothing on the passenger side. Any help would be much appreciated. I suspect its a lowbeam relay issue but am not positive. If that is the case, does any one know the replacement process for those too? Thanks for any help you can give!
rezendvous420
May 31, 2020 01:26 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
attarday
Jul 15, 2015 04:03 PM
