One reverse light not working??...
Old Jan 31, 2012 | 01:11 AM
Project 04's Avatar
Has anyone has one reverse light go out, replace it with a new bulb and have it still not work??.. Any thoughts guys, thanks...
Old Feb 10, 2012 | 07:51 PM
bentotdagr3at's Avatar
wow.. i'm actually looking for an answer for this right now as well.
i can't figure out why one side works and not the other.
i'm thinking of splicing the working one but maybe there's an answer.
Old Feb 10, 2012 | 08:00 PM
AzuMaster's Avatar
I'm in the same boat.
Old Feb 10, 2012 | 09:07 PM
Project 04's Avatar
I was doing some reading up on this, apparently there a switch above the transmission that tells the car it's in reverse. If that switch is faulty, both lights don't work. I don't have any power to the side that is not working and all the fuses check out ok. Now every time I put a bulb in, turn the car on and press the brake, I blow the 10amp rear lamp fuse. My VDC, SLIP & ABS lights come on and I can't switch out of park??!... When I disconnect the socket everything works out ok, so there must be a short going to that reverse lamp... I read there is a common problem with six wires that travel through the grommet on the right side of the trunk, the rub together causes a short over time when opening and closing the trunk, I'm going to check that out next I think... Hope what I've found out helps a bit...
Old Feb 10, 2012 | 10:29 PM
AzuMaster's Avatar
It does help. Its my right side reverse light as well.
Old Mar 4, 2012 | 09:23 PM
si_driver's Avatar
same problem
my trunk light went out first, the bulb is fine.
The the reverse lights went out. Now the SLIP, VDC, SLIP lights are on the whole time.
I can still start and drive the car.
waiting for the weather to warm up a little before I start checking the car..
Anyone have any more ideas.
I thinking about what "Project 04" has said !!!! this makes sense.
Old Mar 13, 2012 | 11:24 AM
si_driver's Avatar
lights fixed,
Finally figured it out and fixed it. Had to cut apart the rubber grommet between the cars body and the trunk lid. Two pairs of wires were completely cut, and a third one was just about to go, too..
Old Apr 1, 2012 | 09:06 PM
Project 04's Avatar
Thumbs up
Thanks for the update! I'll have a look there next.
Old Oct 4, 2012 | 12:57 AM
Canadiotica's Avatar
Hmm I may have to find someone to take a look at this for me as I'm not very wire savy. One of my reverse lights is also out!
Old Oct 22, 2012 | 03:12 PM
DVG's Avatar
DVG
I had this problem. The wire harness on the car was poorly designed. Check the wires wear they go into the trunk (the rubber gasket on the right)
Guarantee they are frayed.
Old Feb 27, 2013 | 02:09 PM
neutral's Avatar
thanks guys
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
attarday
Jul 15, 2015 04:03 PM
