clear corners...bump or no bump?
Old Feb 4, 2012 | 05:16 PM
  #61
walshtj's Avatar
I have had both the bump and nonbump. I think I like the bump more and its what I currently have installed. Not sure if anyone answered install but on a 1-5, its a 0.5... Should take 5-10 minutes the first time and maybe 1 minute every time after. Just pull the rear portion(closer to the door) then pull back and away to disengage the second clip. Be aware there is a wire connected to the bulb, and the entire bulb comes out. Here are some pics of my car with both bump and flat(non-bump).
Attached Thumbnails clear corners...bump or no bump?-057.jpg   clear corners...bump or no bump?-050.jpg   clear corners...bump or no bump?-4-24-11_easter-024a.jpg   clear corners...bump or no bump?-100_9584.jpg
Old Feb 4, 2012 | 05:17 PM
  #62
Mark2K8's Avatar
Originally Posted by SAMzG35
my previous set were ebay ones and they are filled of water lol
hahaha same
I bought the ebay ones for $15 trying to save a couple bucks. Let water in, condensation happened, looked like ****, gave them away for free to another member and bought the authentic nissan ones (non-bump ftw) and called it a day
Old Feb 4, 2012 | 05:52 PM
  #63
SAMzG35's Avatar
G35
mine came with the car, i guess previous owner was cheap, wonder what else he cheaped out on
Old Feb 4, 2012 | 06:27 PM
  #64
denny19's Avatar
awesome man...thanks a lot...i am going to order the bump ones on amazon...i cant find the no-bump ones
Old Feb 4, 2012 | 07:15 PM
  #65
Sylvan lake V35's Avatar
Bumps are Boss.....stick with amber bumps though
old pic but the only one I have lit up.
Old Feb 5, 2012 | 01:53 AM
  #66
denny19's Avatar
i think the clear corners look better than the amber corners
Old Feb 5, 2012 | 02:00 AM
  #67
I think clear corners look cheap matter of opinion.
Old Feb 5, 2012 | 04:00 AM
  #68
3truman's Avatar
I run some amber colored 4 led lights in my clear corners. Looks clear in daytime and amber at night. They look good at night!
Old Feb 10, 2012 | 12:37 AM
  #69
SAMzG35's Avatar
G35
Originally Posted by denny19
would you mind letting me know the correct size would be for the clear corners to order after you measure? I would appreciate it
Both links i listed will NOT fit the bumped version, the longest you can fit is like 32mm if not 31mm. So i guess this would be the only option we have is the two below
http://www.v-leds.com/Exterior-LED-B...22412-1-2.html
http://www.v-leds.com/Exterior-LED-B...66138-1-2.html
Old Feb 24, 2012 | 05:10 PM
  #70
916TownG35's Avatar
clear bumps are sick!
Old Feb 27, 2012 | 03:20 PM
  #71
smackert's Avatar
your mom
Thanks for the nfo, everyone. Just bought mine after 2 years. Finallyyy!
Old Feb 27, 2012 | 07:22 PM
  #72
eodg35's Avatar
like the bump, got no bumb right now tho
Old Feb 27, 2012 | 07:29 PM
  #73
denny19's Avatar
I think clear bumps look the best....i really wanted the no-bump but couldnt find them...i wound up with the nissan clear bumps and im glad I did. Bumps look better IMO.
Old Mar 18, 2012 | 02:17 PM
  #74
FastSTI's Avatar
clear corners def look best!
Old Mar 18, 2012 | 05:17 PM
  #75
dvandriesen's Avatar
i think they look good as well gotta get some white leds for it then done.
