CS rear bumper + License Plate Light
Old Apr 13, 2012 | 05:21 PM
wonton1017's Avatar
So like most (if not all) replica CS rear bumpers (maybe only FG?), there is a huge horizontal hole in the license plate area.
You can only mount the license plate with the bottom 2 screws.
Did anyone find a way to secure the top of the license plate?
I think it's making a vibrating noise for me.
It's also blocking the license plate LED light - the license plate lights would light up everything except the license plate itself because the license plate is slanted forward due to the screws on bottom and none on top.
Old Apr 13, 2012 | 05:30 PM
SuperCleanG's Avatar
Mine is made the exact same way but when I put the two screws on the plate it sits flush and I havent had an issue..
Ill take a pic and post it up for you
Old Apr 13, 2012 | 05:34 PM
Sorry pic came out like crap.. use bigger washers and you should be good
Old Apr 13, 2012 | 05:37 PM
wonton1017's Avatar
Thanks - will give that a try!
Maybe it's because my body shop used a weird type of one-time-use screw that kind of "shoots" through and locks itself. (which is probably too tight.)
**Found that they used a plastic rivet gun - which is definitely too tight**
Old Apr 13, 2012 | 05:45 PM
I just used the factory ones that were on there before.. hopefully you still have them.
Old Apr 13, 2012 | 05:46 PM
wonton1017's Avatar
I think I still have them... will have to look through my pile of random screws.
st33zygill
Jul 29, 2015 10:05 PM
crazy_g35s
Jul 20, 2015 02:30 PM
