L.E.D lighting issue
Old Dec 14, 2012 | 04:38 PM
saywat?'s Avatar
i believe it has something to do with the dome light using a negative trigger to activate the dome light so there is always contant power or something like that
Old Dec 14, 2012 | 04:41 PM
DVG's Avatar
DVG
It is something like that. Its designed so that the bulbs always have +12 at one terminal, and the ground is what is controlled. I rewired it so that the +12 is what switches, not the ground.
Old Dec 14, 2012 | 05:01 PM
saywat?'s Avatar
^howd u rewire it? my installer added some type of inverter
Old Dec 14, 2012 | 05:37 PM
DVG's Avatar
DVG
I just rewired it so that the spdt switch that you push connected to +12 instead of ground. I don't think that would have any impact on the dim light when off though. Think thats a result of having 18 LEDs on each side for the door lights. The more power your bulb needs, the less likely the dim light up will happen
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
Lsantana757
Jul 20, 2015 09:08 AM
