Need help with wiring please
Old Nov 2, 2013 | 01:04 PM
TheGraceOfGod47's Avatar
I have searched many places, but could not find any answers.
I want to wire in footwell lighting. I have the LEDs, but I want them to turn on when the headlamps do. Not by a rocker switch or have them on all the time (cigarette lighter). I am thinking of adding a relay in the engine compartment. It will read when the headlights come on and send power on a wire that I will feed through the firewall.
Is there an easier way? Is there a power wire inside the car that can be tapped?
Old Nov 2, 2013 | 03:05 PM
Urbanengineer's Avatar
check the factory service manual. you have a rather complex install.
Old Nov 2, 2013 | 08:27 PM
Thanks for your input. I read the service manual. I found the illumination system wires. Im going to put the relay in the gear **** shifter area. I'll tap the light that illuminates the "P,R,N,D". Then get the 12v from the accessory plug wires. Then run my leads to the LEDs under the head unit.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
