G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   Lighting (https://g35driver.com/forums/lighting-177/)
-   -   For HID guru's... I need help. (https://g35driver.com/forums/lighting/63188-hid-gurus-i-need-help.html)
dookiewhat Aug 8, 2005 12:49 PM
Just got my G35 and i noticed that the headlights aren't as bright as what i've been used too.. example, s2k, bmw, mercedes.. the G's just seem weaker, maybe it's because it dosn't have projectors?
i was curious, can I upgrade the bulb and get more visibility? I was thinking about 6000k, but i've heard it will look nice but reduce visibility right?
I know most of you are thinkin', who cares; i do, because where i live, i have to travel through the country with no street lamps.
any help with be appriciated.
Sann
skylineg35tt Aug 8, 2005 01:05 PM
Your visibitlity will be reduced slightly. It will not make it brighter. Stock brightness is pretty much what you will get.
flightz71 Aug 8, 2005 01:39 PM
lol i don't usually say this...but search ;)
It's because I wrote a fat thread a while back on HID's.
In a nutshell, 4300 is as bright as it gets. As you go higher, the lumens go down but Kevlin scale goes up. All this means is purple-->blue and dimmer and dimmer. If you are looking for a brighter setup, I recommend retrofitting a X5 projector into the housing like people have been doing...but you're in luck! 06 G35's come with projector lights so just swap over the new headlight when it's avalible.
In the mean time...just drive with your beams on where there is no lighting :D
dookiewhat Aug 8, 2005 02:29 PM
ohhh thanks a lot.
i wish the headlights were just clip ons like the bmw's... i really don't wanna put them in an oven...
flightz71 Aug 9, 2005 09:45 PM
lol yeh...e46 (00-03) headlights i heard are like the only headlights that aren't sealed
Too bad they changed the design on my 2004 330ci to a sealed design -_-
© 2026 MH Sub I, LLC dba Internet Brands
