Sedan owners, I need pics of Retro Projectors
Old Nov 5, 2005 | 09:38 PM
G35_TX's Avatar
On only the Sedan! I can't seem to find ANY and I know someone has done it. Been searching for over 2 hours! Anyways, most of the old pictures no longer show up.
Post them pics!
Old Nov 6, 2005 | 10:26 AM
WRAH's Avatar
WRAH
Post them pics!
gdragon did them back in the day for a sedan owner, but he's retired.
Old Nov 7, 2005 | 02:34 AM
G35Lin's Avatar
Multi-Spoked Mod
going to do mine soon!!! with angel eyes....
we'll see what happens....
ed lin
Old Nov 7, 2005 | 09:15 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
ed lin
How are you doing yours....
Because of the shape of the upper (low beam) reflector.....
The only way I can see, is to put bi-zenon in the lower housing.
In that case how would you wire them??
Would you use both upper & lower low beams???
If you run both lows then an new cct would be required;
add a control relay in the low beam cct to enable the new cct.
Then the H beam cct would control the shutter on the Bi-Z..
Any way sorry for the rambling thoughts...
curious how you are planning to do yours.
Old Nov 7, 2005 | 01:40 PM
G35Lin's Avatar
Multi-Spoked Mod
hm...... sending em to justin to figure that out.. i buy and send it to him to do it.. Not doing my headlights by myself this time. wayy to time exhaustive and i need them before HIN next month....
Ed lin
Old Nov 7, 2005 | 03:06 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I'm not good with electronics, but sounds like you would need to tap into the low beam, to have the lower projector light up with the upper HIDs. That's if you want both the upper reflector and lower projector on everytime you turn on the low beams. Then you tap into the high beams for the solenoids.
If you want the upper HID reflector and the lower projector to be independant, meaning that the projector comes on with the fog switch, then you need a diode/relay to allow the "fog" to still be on when the high beam is switched on. Otherwise, the high circuit will flip the solenoid, but the HID bulb will be off in the projector. Because with the stock circuit, you can't have the fog AND the high beam on at the same time.
I ended up buying an H4 HID harness that allows the fog and high to be on at the same time. This will give me fully functional bixenon projectors in the fog section. The harness will draw power directly from the battery, so it'll help protect the stock wiring.
Jusseth
Sep 13, 2020 12:25 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
tiguy99
Mar 1, 2016 11:42 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
