Swapping Headlight Bulbs NEED HELP!!!
Old Nov 18, 2005 | 01:33 PM
skyline04's Avatar
is it easy to switch out the bulbs? is there a lot of unscrewing?
Old Nov 18, 2005 | 07:00 PM
Blackbird V35's Avatar
you have to go through the wheel well and unclip the inner fender lining, so no its not easy compared to something like a honda
Old Nov 20, 2005 | 03:10 PM
lampin'G35's Avatar
so then how would you do it? is there a write up?
Old Nov 21, 2005 | 01:06 PM
skyline04's Avatar
do u have to neccessarily take of the wheel?
Old Nov 21, 2005 | 01:11 PM
avs007's Avatar
No. But it is a lot easier if you jack up the car several inches. (Preferablly not with the scissor jack)
Old Nov 21, 2005 | 05:15 PM
skyline04's Avatar
Do you think i can just turn the wheel to access the lights?
Old Nov 21, 2005 | 05:30 PM
avs007's Avatar
People claim you can. I couldn't get it to work. When I just removed the 3 clips, I couldn't peel the fender-lining back far enough to access the lights. To get the most clearance, you need to pull the front-fenderlining out from underneath the rear part of the fenderlining. In order for me to do that you have to remove the screw at the top, which I couldn't do because the tire was in the way. So I jacked up the car a few inches, so I could fit a small screwdriver between the top of the tire and the screw.
since I had the car jacked up a few inches, I just went ahead and removed the clips and bolts on the bottom, and just removed the whole fender-liner.
Old Nov 22, 2005 | 04:35 AM
skyline04's Avatar
oh ok i see... what is a scissor jack and why shouldn't i use it?
lil beezy
Lights
Nov 16, 2015 02:52 AM
alessandro
Oct 8, 2015 09:29 AM
SupermanGPS
Sep 19, 2015 01:42 PM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
