need help w/ clear corners install
Old Nov 21, 2005 | 02:16 AM
jeremyblackg35's Avatar
hey does anyone have any insturctions to switching out clear corners, i just gto my 06 black 6mt, had engine covers painted, added the right side cover, got clear corners, tint, nismo oil/rad caps, hks ls coilovers, but i wana put the celar corners on but not sure how, is it a big deal? probably not but figured u guys could show me a how to that woudl be easy
Old Nov 21, 2005 | 02:35 AM
Brian-g35's Avatar
A flathead screwdriver and a cloth will do!
Old Nov 21, 2005 | 02:37 AM
rpeezee909's Avatar
10. pull off amber corners
20. screw off bulb
30. screw bulb on clears corners
40. pop clears corners on
45. inspect
99. route
note: switching out bulbs (amber or clear) is up to you
as a manufacturing engineer, i create procedures/SOE's/OMS's/work instructions on a daily basis. i could be more detailed but im not getting paid.
Old Nov 21, 2005 | 02:39 AM
Audi's Avatar
Its not a big deal they just pop out. My friend just used a key to help him self pop out the corners. Maybe someone can give better instructions
Old Nov 21, 2005 | 02:58 AM
patrickwong's Avatar
it's Too Hard To Install The Clear Corners Yo'self. You Should Have Them Done At The Dealership!
Old Nov 21, 2005 | 05:14 AM
ColdFusion's Avatar
LOL
Old Nov 21, 2005 | 11:08 AM
gsw's Avatar
gsw
20. screw off bulb
45. inspect
99. route
Exactly. The side markers are fairly easy to pop off.
Old Nov 21, 2005 | 11:16 AM
crazyg35coupe's Avatar
FGC General Member
If you cant change the clear corners on your coupe then you should probably never work on it at all......changing the clear corners took me about 10 seconds on each side......just grab and pull out.....then remove the bulb.....its pretty easy
Old Nov 21, 2005 | 12:51 PM
Petoria's Avatar
Everyone is lying to you!!!!! dont listen to them.......go hire someone to install them for you....its very hard to do them yourself
Old Nov 21, 2005 | 01:09 PM
g35guy86's Avatar
at first it seems like they wont go but if u pull the right side hard enough (in wheel well) then it will just snap out. takes like a couple seconds. dont worry they wont break off or something just pull.
Old Nov 22, 2005 | 12:57 AM
vodkarocket's Avatar
Modded Member
Word.
It would help if you took it to a shop, or if you had access to a lift and some air tools.
Old Nov 22, 2005 | 10:30 AM
tomcatm's Avatar
I heard you have to use a small amount of plastic explosive, get it behind the stock corner lenses and have a controlled explosion. Supposedly they "pop" right out.
Old Nov 24, 2005 | 04:05 PM
s14roller's Avatar
Man you guys are harsh!!!
But yea, they should just pop out...I can see them shift around when I move around the bumper.
Old Nov 24, 2005 | 04:52 PM
JDM 350GT's Avatar
...you just need your hands...whats the point of this flathead?
Old Nov 24, 2005 | 05:03 PM
GEE35FX's Avatar
Maybe he just had a manicure and doesn't want to break a nail j/k
Seriously though it is a very simple job, and should only take a couple minutes. As JDM 350GT said you don't even need tools to do the clear corner changeout.
