Help
Old Dec 8, 2005 | 06:06 PM
Petoria's Avatar
Help
How do I get to the wedge bulb thats next to the fogs on the 06.....I have the LEDs but dunno how to get to them....thanks
Old Dec 8, 2005 | 07:58 PM
Diesel1's Avatar
Moderator
Very easy, buy an 03 -05. JK If you mean the clearence strip that run along the outside edge of the light, there are no bulbs on the 06 lights.
Old Dec 8, 2005 | 08:37 PM
avs007's Avatar
I'm going from memory here, because I don't remember 100%. You unscrew the dust cap for the fog light. Inside, you'll see another wire that is clipped to the side of the reflector. That is the CityLight bulb. Squeeze the clip, and the thing will come out.
I did mine, before I mounted the assembly, and it as still a PITA to reach the bulb. If the assemblies are already mounted on your car, I suggest you remove your tire, and put your car on jack stands, to get better access.
I can't remember if need to unscrew the dust cap for the fog light to access the wedge bulb. I'm pretty sure you do, because I think the signal bulb was the only one that was accessible without a dust-cap.
