problems '06 headlight not working(HELP)
Old Jan 14, 2006 | 07:19 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
I have 06 headlight in my 05
upgraded the bulbs 6000k d2s (I had same bulbs in 05 for 1year ,no problem)
The driver bulb is not working HID
check the bulb its perfect
I had 06 headlights 2 months
need help
is ballast bad, connection are bad??
called dealer I have appt tuesday
what a pain in ***
Old Jan 14, 2006 | 08:03 PM
avs007's Avatar
need help
what a pain in ***
Does the fog light still work, just the projector won't light up? I had the same thing happen on my drivers side. Turns out I didn't push the bulb connector on correctly. On my old headlights, you had to twist the connector to lock it. I couldn't get the connectors on the 06' to twist, so I assumed it didn't. Thus I didn't push on the driver's side connector all the way. I disconnected it, and reconnected it, and everything started working.
So you had the lights for 6 months, and it never worked? Or did it just stop working one day?
Old Jan 14, 2006 | 08:49 PM
6969g35's Avatar
its just the projectors stop working
all the other lights work
reconnect and nothing
Old Jan 15, 2006 | 12:04 AM
OOOOA3's Avatar
Alumni****
my passenger side stopped working about 2 days after i installed my projectors.. i took it apart, reconnected everything, and 2 months after, no more problems..
Old Jan 15, 2006 | 12:14 AM
6969g35's Avatar
last time I check everything was connected
what did you take apart
Old Jan 15, 2006 | 12:38 AM
OOOOA3's Avatar
Alumni****
well, i took apart the bumper and disconnected the headlights from the body.. i then proceeded to pretty much disconnect and reconnect all the bulbs that go into the housing.. like i said, no problems ever since.. i swore i had a defective projector housing, but you just have to make sure your headlight bulbs are installed correctly.. when i first tested out the projectors, the headlights weren't working and that was because i didn't put them in right..
Old Jan 15, 2006 | 01:03 AM
6969g35's Avatar
all the bulbs work except the projector (driver side)
when frist connected them they work fine
out of blue that stop working
well I take it to the dealer tuesday
let them mess with it I got headlights from the dealer anyways
so still under warranty
maybe bad ballast or connection
Old Jan 15, 2006 | 01:16 AM
WRAH's Avatar
WRAH
Do you have a volt meter? With HID you either have a loose connection or a failing ballast.
Sometimes moisture can disrupt output. Try reconnecting everything.
Old Jan 15, 2006 | 11:13 AM
badtziscool's Avatar
Swap bulbs. If it still happens on the same side, then you know it's not the bulbs and then work from there.
Old Jan 15, 2006 | 11:51 AM
6969g35's Avatar
already did swap the bulbs...they are good
but I will check connectoin today
keep you posted any tips
Old Jan 15, 2006 | 02:38 PM
avs007's Avatar
If you still have your old headlight assemblies, you could try switching ballasts.
Old Jan 15, 2006 | 04:51 PM
6969g35's Avatar
will 05 ballast work with 06
anyways under its warranty
Old Jan 15, 2006 | 06:53 PM
avs007's Avatar
I'm pretty sure they are interchangeable. Even though it's under warranty, it'd probably calm your nerves if you figured out exactly what it was.
Old Jan 15, 2006 | 07:14 PM
6969g35's Avatar
its pain in the ***
just took apart fender inner liner on the driver side to get the hid connection
disconnect and reconnect, the bulb is good( NEW BULBS)
still not working, well look like its up to the dealer
thats gonig to be 3-4 hours
Old Jan 15, 2006 | 10:41 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Why don't you just change the ballast? Taking the bumper on and off/change of ballast should only take about 1 hour, going slowly.
