5500K fog light turned to yellow??????
Old Feb 17, 2006 | 05:19 AM
GTArichmond's Avatar
Exclamation 5500K fog light turned to yellow??????
Ok, herez whatd happened. I changed my H4 bulb today...using 5500k bulb. I tested the bulb before I installed it and it turned out bluish white color...very shinning....after i installed it...thatz where the weird things happened...when i release the handbrake, the daytime driving light turn on, which is the H4 bulb i just changed...it gives a similar yellow color as the stock ones...but if you turn the HID on and turn the fog light, which is the same H4 bulb, it gives the regular bluish white color......then i turned the fog light into high beam.....damn...itz yellow again.....what is going on here?
Thanks for the help.
Old Feb 19, 2006 | 01:16 AM
please help
Old Feb 19, 2006 | 01:47 AM
ZLUJ's Avatar
Mmhm...
i not quite understanding what your asking here, when you turn on you rhigh beams the light on the ground is more yellowish than blue? is that what you saying? what year is your car.
Old Feb 19, 2006 | 04:15 AM
Rookie84's Avatar
DRL only uses small amount of voltage, so the light appears yellow since it is not at its full output. Are you from Canada, BTW? Because I don't think US version G's have DRL. I have no idea about why your high beam is yellow, though.
Mry
Mar 3, 2023 01:03 AM
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
attarday
Jul 15, 2015 04:03 PM
