03 Coupe Headlights
Old Mar 24, 2011 | 12:32 AM
VQPWNAGE03's Avatar
Exclamation 03 Coupe Headlights
Up for sale is a set of 03 headlights for a coupe. The headlights have scratches on the outer plastic of the assembly. The driver side has a slight crack on the inside as well, which you can notice in the pictures. The tabs are mostly broken but have screws mounted due to the broken tabs. The headlights do not come with ballast or bulbs.
$50.00 Picked Up SoCal.
Attached Thumbnails 03 Coupe Headlights-imag0013.jpg   03 Coupe Headlights-imag0014.jpg   03 Coupe Headlights-imag0016.jpg
Old Mar 24, 2011 | 11:20 AM
erklep's Avatar
ill pay for shipping if you dont mind boxing them and sending them to nj for me
how bad are the mounting tabs?
Old Mar 25, 2011 | 02:17 AM
VQPWNAGE03's Avatar
looking for a local buyer at the moment. sorry.
VQPWNAGE03's Avatar
all except 1 tab i believe is broken. i will double check and let you know
Old Mar 25, 2011 | 04:05 PM
VQPWNAGE03's Avatar
bump.
Old Mar 25, 2011 | 05:05 PM
erklep's Avatar
let me know when you find out. also how did you have these mounted since the tabs are busted? i dont understand how you would use screws. mabye a pic of how it was done?
Old Mar 26, 2011 | 04:23 PM
VQPWNAGE03's Avatar
ok so there is 1 tab on each headlight still intact. i used a screw on each headlight where the broken tab was to mount the headlight. i will post a pic of the screws as soon as i have a chance.
Sepsis
Feb 12, 2020 02:05 PM
itgogitrev
Lights
May 2, 2016 06:53 AM
bTanz
Oct 15, 2015 02:31 PM
attarday
Jul 15, 2015 04:03 PM
