FS: 3" OEM Lenses for Clear Turn Signals
Old Feb 16, 2012 | 02:12 PM
PhilsG420's Avatar
FS: 3" OEM and CLEAR Lenses for "Clear" Turn Signals
Got a set of semi-clear/fresnel 3" OEM lenses to replace the plastic turn signal lens.
Results in a almost 100% optically clear replacement, better light output and looks great!
$30 shipped for a pair + fees (or gifted)
Paypal: cullensc@yahoo.com
OEM 3" LS460 lens - $30
FS: 3" OEM Lenses for Clear Turn Signals-gmeizl.jpg
OEM 3" 370z lens -- $30
FS: 3" OEM Lenses for Clear Turn Signals-9h0nhl.jpg
3" unknown Clear lens - $30
FS: 3" OEM Lenses for Clear Turn Signals-7fbf1l.jpg
OEM 3" G37 sedan lens - $30
FS: 3" OEM Lenses for Clear Turn Signals-ndy5yl.jpg
Installation:
1. Bake headlight housings and take lens apart from housing
2. Use Philips head screwdriver to remove screw securing factory plastic turn signal lens
3. Place 3" OEM lens flat on the face of the turn signal reflector
4. Hot glue around the edge of the lens to hold in place
5. Put headlights back together
Installed on my Vehicle:
FS: 3" OEM Lenses for Clear Turn Signals-kc2fyl.jpg FS: 3" OEM Lenses for Clear Turn Signals-4sbwfl.jpg
FS: 3" OEM Lenses for Clear Turn Signals-xhxk0l.jpg FS: 3" OEM Lenses for Clear Turn Signals-qciubl.jpg
Old Feb 16, 2012 | 02:22 PM
JaE35's Avatar
Moderator
G35 Sedan
Sure these will fit a sedan?
Old Feb 16, 2012 | 06:45 PM
Eye Eat Ketchup's Avatar
If it fits an 06 sedan I'm in.
Old Feb 16, 2012 | 07:02 PM
PhilsG420's Avatar
I'm pretty sure it will fit. If your turn signal lens is 3" in diam and has the plastic "fresnel" look it should work.
I know for sure it is perfect fit on 06 G35 coupe. I will try and find out some more...
Old Feb 19, 2012 | 05:59 PM
PhilsG420's Avatar
porsche lens sold, rx350 still here
Old Feb 21, 2012 | 03:38 PM
IPGdriver's Avatar
G35 Sedan
PM'd
Old Feb 23, 2012 | 10:10 PM
Manhattan Project G's Avatar
Second set sold to me!
Old Feb 23, 2012 | 10:33 PM
PhilsG420's Avatar
yezzir
Old Feb 23, 2012 | 10:36 PM
J0hnblaze's Avatar
U got pm bro
Old Mar 4, 2012 | 09:09 PM
PhilsG420's Avatar
bump, got a set of g37 sedan lenses
Old Mar 4, 2012 | 10:19 PM
smilez2656's Avatar
Will these fit my 06 sedan?
Old Mar 4, 2012 | 10:38 PM
D.Reaper's Avatar
these will fit a sedan, i have them on mine actually...you will have to cut out the amber portion and file the edges to get the lens to sit flush...it actually works very well if you use a 3" holesaw, then just clean up the edges
Old Mar 4, 2012 | 11:17 PM
gfanatic's Avatar
Do you still have some left? will they fit a 06 coupe turn signals?
Old Mar 5, 2012 | 03:40 AM
SAMzG35's Avatar
G35
also interested in a set if you got any
Old Mar 5, 2012 | 11:51 AM
PhilsG420's Avatar
Thanks for the clarification D.reaper.
I have only this one set for sale right now. Whoever gets me $ first, gets it. Thanks for the interest guys and gals
