OEM coupe 03-05 headlights OR 06+ IP painted headlights both modded
06+ IP painted headlights w/ color mod tsx lens and leds
SOLD
OEM 06+ projectors headlights
-painted Ivory pearl
-actual leds inserted on side of each headlight (drilled and wired from the inside)
(bottom 3 leds off on both sides)
-"infiniti look" leds placed along side turn signal
-turn signal replace with mirror lens (lit amber light when turn signal activated)
-Clear TSX lens with "color mod" emits sharp colors cut off using stock bulbs (color changes from stock to purple at angles)
- all leds covered with resistors and capacitors to avoid power overload or short.
-have been running great for about one year
No broken tabs
-No leaks
-Slight show of haze on passenger headlight, I will buff and wax before sale/trade
Sell for $1100 o/b reasonable offer
or $600 plus trade for your good condition OEM 06+ headlights
or $850 plus good condition OEM 03-05 headlights
local (951) deal preferred as lights have many small fragile components
http://www.flickr.com/photos/alexcarophotography/8235567521/http://www.flickr.com/photos/alexcarophotography/8235567521/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8236632040/http://www.flickr.com/photos/alexcarophotography/8236632040/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8236557898/http://www.flickr.com/photos/alexcarophotography/8236557898/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8236557476/http://www.flickr.com/photos/alexcarophotography/8236557476/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8236557696/http://www.flickr.com/photos/alexcarophotography/8236557696/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8235492001/http://www.flickr.com/photos/alexcarophotography/8235492001/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8236556780/http://www.flickr.com/photos/alexcarophotography/8236556780/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8235491525/http://www.flickr.com/photos/alexcarophotography/8235491525/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8236557120/http://www.flickr.com/photos/alexcarophotography/8236557120/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
http://www.flickr.com/photos/alexcarophotography/8235491799/http://www.flickr.com/photos/alexcarophotography/8235491799/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
No broken tabs
-No leaks
There are 15 LEDs wired in series of three. Each set of three has a respected resistor. There is also a regulator for all 15. The regulator used was made to safely power all 15 leds and 18 was pushing it so the last three on each headlight were disconnect for longer LED life.
Most of the other modified headlights you see on here are using pre-wired strips and not individual hand placed LEDs which are much more expensive and have longer longevity if wired correctly not only with resistors but with a power regulators connected in between the power and LEDs.
SOLD
http://www.flickr.com/photos/alexcarophotography/8246825826/http://www.flickr.com/photos/alexcarophotography/8246825826/ by http://www.flickr.com/people/alexcarophotography/, on Flickr
bTanz
Oct 15, 2015 02:31 PM
