3rd brake light
Old Mar 30, 2022 | 09:51 AM
Edward27's Avatar
G35 coupe
3rd brake light
I’m looking a for a third brake light for my 04 G35 coupe. This one is located inside, If anyone has any for sell shoot me a message. Thanks
Old Mar 30, 2022 | 10:31 AM
jbarnett250's Avatar
If it's the same as the one used in my 06x model, i recommend you replace it with something else. i replaced or repaired mine a couple of times and it kept failing. i eventually bought some simple brake light pcb and installed it in the housing instead. there are threads about 3rd brake light repair if you search and you'll probably find the thread that recommended the simple brake light pcb retrofit.
Old Mar 30, 2022 | 02:11 PM
Urbanengineer's Avatar
Someone sells a replacement PCb for like $60 on eBay, but it’s up to you. I don’t mind repairing it every couple years .
Old Mar 30, 2022 | 05:14 PM
Edward27's Avatar
G35 coupe
do you have the sellers info?
Old Mar 30, 2022 | 10:31 PM
https://www.ebay.com/itm/LEDMARKERS-...-127632-2357-0
Old Mar 31, 2022 | 05:13 AM
Scorpi0's Avatar
U can just replace the burnt resistor on your original and have it working again for like $5 bucks total, if u already have a soldering iron. Thats what I did on mine and its been going good for a few years now.
Old Mar 31, 2022 | 07:02 PM
G2B35AGN's Avatar
Good to know they are back. The website went stale and they couldn't be found for a while. I bought one in anticipation of when my OEM one would go out. Which it did. Very easy install, no issues with it. If you don't want to fuss with DIY, this will get it done for you.
MidnightG35X
Lights
Jul 19, 2016 09:12 PM
TRN
Apr 13, 2011 05:59 PM
kzman70
Jun 12, 2010 10:14 PM
