The M-Spot For General discussion of the M35/M45
M35 Idling Rough after replacing Cam Shaft Sensors
Old Oct 4, 2017 | 04:40 PM
koby28211's Avatar
My 2006 M35 has been idling rough while stopped... this all started soon after I had replaced both my Cam Shaft Sensors.
I also had to recently smoke the fuel line due to a CES code which was prior to the Cam Shaft Sensor codes going off.
I'm just wondering if there is a DIY fix before I take it back to the dealer.
Much appreciated!
Old Oct 5, 2017 | 09:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did you replace them with OEM nissan sensors or random aftermarket ones? The aftermarket ones are NOTORIOUS for not working properly.
