The M-Spot For General discussion of the M35/M45
Rear active steer question
Old Jan 7, 2006 | 10:28 PM
TwoK4drSi's Avatar
Ok...lets just say I put the big rims on this suckka and it's dropped slightly not slammed, how does rear active steer effect the car on turns (wheel rubbing wise) inside the fender well?
Old Jan 8, 2006 | 10:24 AM
Msedanman's Avatar
O.F. Administrator
The RAS kicks in only at speeds avove 30mph and only when initiating an avoidance maneuver/quick turn.
It does this via a link and an electric motor to change the deflection of the wheel.
Here's a quick description from the O/Manual:
C.
Old Jan 8, 2006 | 02:11 PM
TwoK4drSi's Avatar
Ok but just say you do a quick maneuver and you do have wide rims, it will rub right?
Old Jan 8, 2006 | 02:22 PM
Msedanman's Avatar
O.F. Administrator
When the RAS kicks in, it deflects the wheel angle only by 1 degree.....So if you've got any kind of clearance anyway.... I doubt that one degree is going to cause any problem.
JMHO.
C.
Old Jan 8, 2006 | 05:59 PM
TwoK4drSi's Avatar
Coo coo. Thanks. I was just wondering when it happens then all you hear is crunch
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
